M1 ESP 5W30, when did it lose dexos2?
Southern Ontario
I "discovered" an unopened 5 quart jug of M1 ESP 5W30 in a long forgotten cupboard but to use it in our 2018 Golf R I would need one more quart. So I picked up a quart bottle of the same but I noticed this new bottle doesn't list dexos2 as did the much older 5 quart bottle. I have been out of the BitOG loop for several years now...when did M1 ESP 5W30 did it lose the dexos2 certification?
A YT celebrity recently said that Dexos certification would need to be retriggered if the base oil is changed, but API certs do not require it. I believe Dexos 2 is going away anyway so companies are probably not bothering to pay the club dues, and/or going through the motions for the replacement certs.
I delved in to the API - PDFs a few times and fell asleep. Maybe the same docs are public for Dexos, I'd be interested in falling asleep to those PDFs too but a quick google search didnt give me much.
still sell this oil in EU, new name is
New approval from GM is coming. Mobil1 usually does not list approvals that will become obsolete.
If you change any little thing without redoing, mainly repay the licencing fee you lose your dextros badge.
They may just decided it's not worth it to keep running the dextros badge after changing something.
Is that dextros, dextrose or dexos?
The licensing agreement will specify exactly what can be changed and what cannot, much like the API interchange requirements.
My bad some how my phone learned that dextrose is a word and dexos is nothing.
I heard if any little change was made they oil maker had to redo the dexos certs and that involves revealing every ingredient to gm and paying gm probably a lot of money for each certified product.
No?
Could be wrong.
I briefly looked into it to see what being dexos approved ment, if it was really important and if being dexos certified meant that oil was measurably better than non approved ones.
"Same"? Obviously you feel extremely certain . . . :ROFLMAO:
PAO? Little to none. MSDS says UP TO 15 percent.
Add pack? I strongly doubt it's the "same", but I'm
no expert - unlike to you.
However, we're still talking about the use in a Mk7
Golf R what requires VW 502 00 and/or VW 504 00.
Pour point indicates healthy PAO levels. However, KV100 is lower than old ESP 5W30. Probably bit changed to get other approvals.
ohh no...
