Weirdness factors:code:
Vehicle 1990 Saab 900, 2.0L I4 (N/A)
Miles on engine 165,500
Miles on oil 6,500
Time on oil 13 months, 2 weeks (02.Oct.02 – 16.Nov.03)
Oil capacity 4 qts
Oil added 1 qt, Saab ACEA A3 (API SJ) 5W-30 semi syn
Oil filter ACDelco PF13, not changed during interval
Air filter K&N drop-in, last cleaned at 150,000 miles
Driving Use 95%+ short trips (less than 10 miles)
Copper 9
Iron 13
Chrome 0
Lead 0
Aluminum 3
Silicon 0
Molybdenum 0
Sodium 10
Calcium 2288
Tin 0
Potassium 0
Magnesium 79
Zinc 1312
Water Neg
Glycol Neg
TBN 8.5 (ASTM D5984-96)
Viscosity 14.2
Part count >=5um 8345
>=15um 276
ISO # 20/15
Lab S.O.S. Fluid Analysis, H.O. Penn Machinery
1) Right after I filled with this oil we had 3 weeks of sub-freezing temps (last 3 wks of Oct 2002). IIRC, it never got above freezing day or night for more than one of those weeks, & the rest of the time it was around 0°F at night & in the 30’s during the day. So that was good way to start this interval, don’t you think?
2) The car is used as the household pickup. During the spring & summer I hauled home several loads of landscaping & decorating materials (trees, rocks, tile, cement, etc; usually around 850-900 lbs max).
3) I pulled the sample in Nov, but never got around to filling out the form & sending it in. It’s been sitting in my garage all winter (nearly 3 months). The lab said it shouldn’t affect their readings.
4) The lab also said mixing the two oils (Saab 5W-30 VOA here) was probably the reason why they couldn’t get valid oxidation/nitration numbers.
5) Moly is zero & zinc is up, compared to the M1 15W-50 VOA info we have. I’m wondering if maybe I got a batch with a slightly different composition?
[ February 24, 2004, 04:18 PM: Message edited by: Eiron ]
