Originally Posted By: SubLGT
From a Q&A in 2002 with Dr. Burkhard Wies:
".................Question: Are there any other improvements [of winter tires] which could be achieved through different means?
Answer: If the tyre pressure could be adapted to the driving and load conditions of the vehicle, improvements could be made to traction and comfort, without adversely affecting the service life of the tyre.
Particularly with traction in snow and especially on loose ground, if we could reduce the tyre pressure from 2.5 to 1.5 bar, spectacular improvements of up to 30% could be made. This would however have negative effects when braking on dry roads and in handling, so any adjustments to the tyre pressure always have to be in the correct ratio to the driving condition.........."
Continental Q&A
Be careful here. If you can get a tire to contact the road surface, the grip increases dramatically - and the way to do that is to reduce the size of the footprint = higher pressure.
- BUT - if you CAN'T reach the pavement, then it is true that grip on snow is better with lower pressure = larger footprint. I am sure that is what Dr. Wies meant - after all the discussion was snow traction and that is how engineers think. (Trust me, I know how engineers think!!)
What we used to do is use 5 psi more, then if we got stuck and couldn't get out, then lower the pressure to get us unstuck. Then reinflate once back in the barn.
