Lubricant for sliding plastic parts?
Cordelia, CA
I have a pair of motorcycle race boots. They have a sliding plastic mechanism designed to prevent the ankle from over extending in any direction.
The boots came with a silicon gel lube which does not last long at all. When the lube is gone, the ankle protection mechanism makes a lot of noise.
I am wondering if there would be a better lube for this application.
Originally Posted By: rshunter
Oxtar, or TCX as they're now known as, by any chance?
Oxtar TCS EVO RX
Thanks for the tips.
California is a sports car and motorcycle paradise, especially the San Francisco Bay Area. I love it.
I work in a refienery, so there is little "kookiness" to deal with.
While searching, I realized that I have a silicone & krytox teflon spray at home(I just remembered it as being silicone spray until I saw the can online). I'll have to try that.
Oxtar TCS EVO RX
Now how do you suppose I knew that? Hehehe...
On mine, I use a DuPont Teflon spray lube that I picked up at Lowe's. I don't recall which one it is specifically, as I've got a couple of different ones. It dries after application and is also good for lubing your drive-chain.
If it'll help, I'll check out which one it is and post it when I get home.
Cheers
Thanks. I'll pick up a can. I think the Dupont Silicone w/Krytox Teflon would have worked, but I can't find it. Must have got lost in the move...
I think the product you mention will be even better.
What I wound up with was Dupont Teflon Multi-Use Dry Wax Lube.
I applied it about a week ago and ridden about 750 miles since, getting the boots wet once.
They are still quiet. I am very happy.
