You can't even get sarcasm, lol. Apparently you don't underhand the W rating either.What footnote in the manual tells us that thinner oil is better for the grandma duty cycle, and how is 0w not satisfying said requirement?
You don't know how much MOFT headroom the recommended viscosity on the cap really gives - many wear studies show xW-20 is pretty much on the edge of enough HTHS to give adequate full time protection under all use conditions - Ford apparently gave in to CAFE and did what was best. Going up a grade from xW-20 will indeed add some headroom. That's the main point of doing so. You do you ... and you might want to stop your obvious trolling.Because for most cars on the street, they're being fed whatever grade is on the cap by jiffy tech and we don't really hear of failure rates that indicate ragged edge operation. So it appears 1) headroom does exist and 2) I do grasp the logic, and yet my purchasing choices are indicated in my signature.
A 2GR-FE fed 0w-20 per backspec (my cap says 5w-30) will still run when roaches roam the earth, despite whatever front cover leaks it may have.
I'll list my stash on marketplace tonight and start to stock up on 15w-50.
