LSJR Calls Out YouTube AI-generated Video Referencing Him
Central Texas
LSJR is calling out an AI-generated video referencing him saying 5W-30 is better than 0W-20. He provides data from his analysis showing that 0W-20 can provide better wear protection... unless the oil shears out of grade. Then the tables turn.
LSJR confirmed that thicker viscosity can be used in other countries for the same engine. What is the problem then using it in US? Seems to contradict himself.
He did, but then he start saying that 0w20 can provide better protection assuming it does not drop in viscosity. Confusing…. I just want to use other country recommended viscosity
Not confusing at all to me. Pretty clear and straightforward. By all means, use what you like, but don't automatically expect a higher viscosity to provide better wear protection, because often, it does not.
