Amen!Need Chip on BITOG!
He talks about high amounts of certain types of moly lead to deposits. I believe he said it’s because of the sulfur content. “More additives can lead to more deposits.”Need Chip on BITOG!
So from this group it looks like Pennzoil Ultra Platinum is a very good OTS product. Too bad it doesn't come with stickers. @TiGeo /Sarcasm
Dressed up for the occasion. A man of class.
Other guys say some oils are junk.Funny, some BITOGers told me break-in isn’t real in modern engines.
Not exactly. The argument isn't whether break-in occurs but whether this early material causes additional wear of the engine. The argument is that there are millions of automobiles on the road today which did not have a break-in service and engines aren't failing left and right.Funny, some BITOGers told me break-in isn’t real in modern engines.
With Chip now working with Lake, I hope the controversy whether the results from data analysis from SD are statistically significant will subside.Ok. What did everyone think? I enjoyed it.
I found it contained very good information. Worthy of BITOG data!Ok. What did everyone think? I enjoyed it.
Exactly. A sheared 20 grade is bad. A sheared 30 grade still protects like a non sheared 20 grade. It’s all about the headroom.In one of Lake's recent videos, he had a slide showing what happens to wear metals when 0W-20 and 5W-30 fall out of grade. At the beginning of this presentation, he mentioned it, but never showed the slide or discussed it. Bottom line from the earlier video, as long as 0W-20 oil stays in grade, wear metals stay low, but as soon as it goes out of grade, wear metals increase quite a bit. Similar results with 5W-30 going out of grade, but the wear metal increase was significantly lower than 0W-20 having gone out of grade.
He was talking about not needing Superchat donations.His wording is always interesting..............doesn't need this for money.....hires people........
IIRC, in this same video he says that most 5w30s shear down to 20 regardless and he suggests just moving to 5w20 because of its ability to resist shear more than a 5w30.Exactly. A sheared 20 grade is bad. A sheared 30 grade still protects like a non sheared 20 grade. It’s all about the headroom.
