Originally Posted by Chris142
Originally Posted by Nick1994
It all depends on the person you're buying it from.
Find out how much it costs to have it towed on a tow truck. Might make sense to do it yourself and rent a trailer. Here's a company that rents trailers. They have a 20' tilt deck that might work. Of course you'd need proper strapping of some sort with chain binders, they might have them.
https://www.nationwidetrailers.com/--Trailers-For-Rent-In-Houston
He also needs a class A license to pull that much.
Why? It doesn't say CDL required for the tilt deck trailer and he'd be under 26k. I'd have a towing company move it since you don't have the binders. Just call them an hour or two before you go to get it and I'm sure they can meet you there to pick it up. Agreed on not needing a forklift license, not much too them and use common sense when operating/working on one.
Federal regs say any trailer with a gvw over 10k requires a cdl unless it's an rv trailer then 15000k. The 26k only applies to the power unit.
Hmmm. Missouri is different. If the GCWR isn't over 26k no CDL required here. Straight from our CDL test booklet...
![[Linked Image] [Linked Image]](https://www.bobistheoilguy.com/forums/attachments/usergals/2020/03/full-47550-41837-4e6afa2a_064c_4566_b1ed_741441351016.jpeg)
