Run it for 8k do a oil analysis to see what you have leftRun it, I'd run it, I ran it once, my uncle runs it, run it-You'll like it and last but not least...run it for 10k.
No engine that specs xW-20 is going to be harmed in any way by running a xW-30 ...
Meh, doubtful it makes any difference in normal engine operations in North America, with maybe some exceptions, with modern engine oil bases and the rigorous testing and spec's. I have used 5W-30 in summer in a Ford and it didn't do any harm nor do I think it protected any better than a good synthetic 0/5W-20...the 30 will actually give more protection (more HTHS, more MOFT), especially in very hot climates.
Never said you claimed it would - it was a general comment. Lots of people seem to think that a xW-30 will "blow-up" their motor when the manual calls out a xW-20. Going up a grade never hurt any engine, but going down a grade has the potential to hurt a engine.Never said it would.
Pretty standard practice to retain adequate MOFT headroom in the higher strung engine with the potential to get the oil hotter. Most manufacturers seem to go up a grade on their turbo engines, for the added protection factor.They also recommend 5W-30 in the turbo charged version of my engine..
I said a xW-30 will give more protection (more HTHS, more MOFT), which is true - it's basic tribology backed up by many wear vs viscosity studies. Nobody knows just how close moving parts are to rubbing and wearing while driving atound, so having some added protection headroom can't hurt, just like you do with 5W-30 in the summer instead of running xW-20. If you're so confident in xW-20 to give full protection all the time, then why not run it in the summer too, and while pushing the engine hard in blistering heat?Meh, doubtful it makes any difference in normal engine operations in North America, with maybe some exceptions, with modern engine oil bases and the rigorous testing and spec's. I have used 5W-30 in summer in a Ford and it didn't do any harm nor do I think it protected any better than a good synthetic 0/5W-20...
Pretty much every oil related failure I've seen since I started using working on cars for a living was due to a lack of oil, even Hyundai's, it not directly the 5w20 and long drain intervals that kills them it's because they wear and start burning that 5w20 and then blow up cause the owner never checked the oil.Warranty denied? no. With so many synthetic long drain oils on the market I imagine lubricant related failures are extremely rare on an in-warranty vehicle. Today is much different than say 20 yrs ago when shelves were full of conventional or semi-syn and only a few automakers were pushing OCI's out past 10k miles. Back then, especially with the Euros, some engines were designed around a min HTHS in either a 30w or 40w, and the problem was that there were only a few 30w oils on the shelves which met the min.
Today oil grades revolve around CAFE. This doesn't mean that the 20w oils are insufficient it just means that the automaker won't encourage someone to use something thicker than what the vehicle was certified with.
And it's possible the 5W-20 doesn't do well in those engines and causes them to start burning oil. Wear is caused by inadequate lubrication and/or inferior metallurgy. The ring pack is a very harsh environment and quite demanding for oil, and ring wear is pretty much at the top of the list when it comes to engine component wear.Pretty much every oil related failure I've seen since I started using working on cars for a living was due to a lack of oil, even Hyundai's, it not directly the 5w20 and long drain intervals that kills them it's because they wear and start burning that 5w20 and then blow up cause the owner never checked the oil.
Another BITOGer was just told that his dealership extended warranty was invalid because of DIY oil changes. Extended warranty's verbiage just said he needed proof of maintenance, but oil and oil filter receipts plus a log were deemed to be unacceptable.If the dealership is invoking the warranty just based on no receipts then that’s not right.
What brand of vehicle?Another BITOGer was just told that his dealership extended warranty was invalid because of DIY oil changes. Extended warranty's verbiage just said he needed proof of maintenance, but oil and oil filter receipts plus a log were deemed to be unacceptable.
OEM goodwill appears to have covered most of the repair, but yeah, DIY maintenance logs can be an issue.
I bought a new GM that takes 0W20 dexos rated oil. I used K&N 0W 20 in my previous vehicle and have a stash of it. It does not have the dexos symbol on the oil container. Note that the oil was purchased in January of this year. I called K&N technical service to ask if it was Dexos rated and they said yes. I wonder why it does not have the dexos symbol on the oil container.It may be interesting to hear but irrelevant if the manufacturer specifies oil X and you used oil Y b/c all they have to say is "they didn't follow the manufacturer's recommended blah blah blah".
I wonder if maybe K&N didn't want to pay GM to have their Dexos symbol on their bottles.I bought a new GM that takes 0W20 dexos rated oil. I used K&N 0W 20 in my previous vehicle and have a stash of it. It does not have the dexos symbol on the oil container. Note that the oil was purchased in January of this year. I called K&N technical service to ask if it was Dexos rated and they said yes. I wonder why it does not have the dexos symbol on the oil container.
Sorry but what a crap and irresponsible comment. Tens of thousands of Hondas, Toyotas, and Fords have not had any such issue. Blaming OEM failures on a few CST's is just foolish!And it's possible the 5W-20 doesn't do well in those engines and causes them to start burning oil. Wear is caused by inadequate lubrication and/or inferior metallurgy. The ring pack is a very harsh environment and quite demanding for oil, and ring wear is pretty much at the top of the list when it comes to engine component wear.
It's easier when you have a German car... since they have their specifications for oil to be used, AND you don't have to buy the manufacturer's branded oil, as there are plenty of aftermarket options that have been certified by the auto manufacturer to meet their specifications.Federal law requires that the manufacturer shows that your choice of lubricant caused a failure. Good luck with that.
Let's say for example, a customer uses Signature Series in their vehicle, in an extremely unlikely event of an lubricant-caused failure, and the vehicle manufacturer says you have to use an oil that meets API-whatever specification. Since Amsoil Signature Series does not have an API oil license, like the OE and XL series, technically, it's unapproved oil.Please don't imply Amsoil (no Z) is "unapproved".
You actually mix issues.
Using an unlisted/not recommended viscosity can result in denial of warranty claim if the cause is the lubricant. The bad news here is Amsoil will not help you either. That said, absolutely rare, never heard or read about, say 0W-30 used in a car calling for say 0W-20, and for the record, I do this with my own vehicles. My cars, my risk. Some ignorant people actually think doing such a thing voids the entire warranty which is simply not true.
As for "unapproved" lubricants: Bottom line it comes down to how the recommendation and warranty are written. Many are NOT written in hard legal terms. This does not mean you can use any lubricant you want. It means basically if the lube must meets the performance requirements as written.
Topic beaten to death. Just asked in a different way.
No I have never seen it in 43+ years.
A as stated legally it depends on EXACTLY how the "requirement" is written.Let's say for example, a customer uses Signature Series in their vehicle, in an extremely unlikely event of an lubricant-caused failure, and the vehicle manufacturer says you have to use an oil that meets API-whatever specification. Since Amsoil Signature Series does not have an API oil license, like the OE and XL series, technically, it's unapproved oil.
Personally, i use the vehicle manufacturer's oil during the warranty period. After that, then I use whatever I want... which... btw, will there be a Signature Series 0W-16? I would like a PAO/POE oil, with the typical SS stout additive package.
