List an oil Additive you'd use / No Comments
My ope gets a squirt of this.
There are a few lubes I am never without:
  1. NeverSieze or whatever name;
  2. ZEP45 or Breakfree;
  3. Marvel Mystery Oil;
  4. Mobil 1 in a bunch of different weights based upon use. And now a new one;
  5. Marvel Ultimate.
1 through 3 are self explanatory. We won't get into #4. But #5 is a new discovery to me. I've seen the opinions. Eh.
I have stuff from a 8hp log splitter to a JD410j. I run Mobil 1 in all of them. Hydraulics? I run the usual equivalent fluid but this is out of scope. But recently a retailer had Marvel Ultimate on close out so I bought out everything on the shelf. Why? I've used Marvel oil for everything from cutting oil to additives for 30+ years. I works. So I tried it. First in a small engine - a Champion 3100 inverter generator. It cleaned it up from shutting down early. OK, so I added it to the primary generator: EU7000is. But it runs great anyway. No change. And I've played with a few other machines with the additive. Here is what I found:
  1. If you have a good running machine it won't make a noticeable difference. It's not like replacing pump gas for racing fuel;
  2. It doesn't make much difference in big machines as in a little one;
  3. It is well worth keeping on hand for the PITB applications.
I'm not sure what the 'mystery' is but it is good stuff - through out the product line. I keep it on hand.
I used this in my ope that smokes at start up
She has the typical leaks these engines have.
BS 26hp twin.
will see if those stop too. Doubtful.
Starting in the 1970s:
STP in the cardboard can.
Rislone
Bardahl No-Smoke
Bought my first Mercedes 240D and:
Liqui-Moly once then never anything in a Mercedes or Beemer ever again.
Redline Break-in additive (rebuilding motorcycles)
Hotshots Secret Stiction Eliminator (Two 3k OCIs really did de-sludge and stop oil burning in a Chevy 4.3)
Generally nothing. Might do the Stiction Eliminator if presented with a sludgy motor again.
Diesel oil additives have been draining my wallet lately.
Holy flashback batman
