What exactly did those entail?This sounds exactly like a Valvoline thread from 20 years ago.
How overpriced Valvoline conventional was and how the additive package looked no better if as good as most store brand conventionals. If you paid for a premium brand you were crazy if it wasn't Pennzoil.
Disclaimer: The only Valvoline or SOPUS product I have used on a regular basis was VR1 or Rotella.
I wonder if cereal forums exist and folks argue about it?
I honestly think there's a forum for everything!Thank you....HAAHHAHAAHAHA
Funny how some of these threads go. You'll have people put down RP because they say it has the same add pack as Valvoline conventional,but then these same people are the ones who say "You can't see what's in an oil or judge an oil based on a $20 used oil analysis"How overpriced Valvoline conventional was and how the additive package looked no better if as good as most store brand conventionals. If you paid for a premium brand you were crazy if it wasn't Pennzoil.
Edit: I have no reason I wouldn't use the above brands PCMO on a regular basis. It's just worked out that way.
I honestly think there's a forum for everything!![]()
The Honda S2000 had a recall, the engines with the first generation oil squirting jets for cooling the piston bottom where faulty.
In the service bulletin, honda clearly wrote the alle cars are filled with a speciel oil containing Moly from the factory for better break - in of the engine.
When doing the recall and upgrade the oil jets, the mechanics where adviesed to add a moly additive delivered by honda to all engines with less then 15.000 Km/ 10.000 Miles when refilling the engine with oil.
Must be a very Bad thing this Moly adtives and only meant for making money, for sure....![]()
Liqui Moly ist the most widely used brand in Germany. It is the "Best brand" for 10 years in a row at the Nr. 1 car magazine here.
Many friends and Co workers us it, nobody compalins, engines last forever.
It is something special? No. It´s just good, average quality oil. Is it worth high import prices? Doubtfull!
Theire additives are all good and work well. Trust them, they know what they doing.
Find another one out of all the other oils they produce not just from many of them. They don't use it because there is no need for it with the introduction of Tri-nuclear moly (a MoDTC ) and other additives used today which is more effective in smaller amounts and not a solid.
Keep in mind MoS2 was popular in the 60's and 70's long before many of the advances in oil additives used in the formulations of today. Solids are fine in some grease but have no place in modern engine oils or engines.
So what makes LiquiMoly so average as compared to Pennzoil Platinum, Castrol Synthetic? I understand being on par or better than M1 and the excess Fe that shows.
Trav, belive me. I read this bulletin and i was really stunned by myself, because to me it was also very unlikely that a manufacterer used MoS2 in the year 2002. The recall and service bulletin was only done in Europe, not in the US. Some early S2000 Engines where damagegd on the Autobahn....
I try to look around for the bulletin again!
Yes, they wrote cleraly in the bulletin that the MoS2 was not meant to be used continually , only for the first 10.000 miles / 15.000 km = The first regular oil change service.
If a car with more than 10.000 miles / 15.000 km had the recall done, the mechanics should not use the MoS2 additive, just refill it with oil when done.
if you think about it, the S2000 Engine with is extremly high piston speed is maybe the one Exception where use of MoS2 maybe(!) makes sense for break-in. And, generally sepaking, the Japanese car makers are fans of MoS2, to my limited konwledge.
