Yeah, from what I hear. I do like simple though.I'm not sure, I mostly make calls rarely receive them and when I do it's right there on the display so I push the button. EZ PZ.
I think your infotainment is way more sophisticated (read complicated) than mine.
Premium fuel hurts the overall cost of ownership though.Surprise! I thought the Jetta would be way less.
Then again it is in total ownership costs...tires are half the price, it uses less gas etc etc.
I like the SE because the 18 inchers are stiff enough for me. No way would I want twenties..Surprise! I thought the Jetta would be way less.
IF its like the "dip stick" tube on my A4, (the A4 doesn't have one, its the drain access) the tube has two flat spots on either side the allow the two prongs to be rotated into to allow ease of access.The Arteon dipstick.
Wow I didn't want to force it to pull out but it does require muscle.
Being new and all I wanted to be careful. It has two prongs so to speak keeping it on the tube.
You have to rip it out...![]()
It does have one and prior I did look for what you mention. Reason being it was stiff...Happy it does although you need to yank it.IF its like the "dip stick" tube on my A4, (the A4 doesn't have one, its the drain access) the tube has two flat spots on either side the allow the two prongs to be rotated into to allow ease of access.
Yeah Romanian Contis on mineA little time on the Vortex Arteon forum confirms that...guys on twenties are constantly replacing tires and often wheels from hitting pot holes and the like. No thanks. The Arteons on 19s seem fine in this regard, my Passat also wore 19s and I hit potholes so hard once I had to get realigned. Could not believe it didn't blow, but there was no damage. OEM Continentals.
I think @gregk24. Showed us the other day on hereForty one in an Arteon is NUTS! Wonder what I could do if I babied the Jetta?
Yes, 57 if I remember correctly. Just checked, 58.7 mpg.I think @gregk24. Showed us the other day on here
