Originally Posted By: TaterandNoodles
Originally Posted By: moribundman
II need grub control
You need a few hungry moles.
I have a mole problem now due to the japanese beetle grubs. My dogs keep excavating everywhere the moles have been which is the real problem. Along my fence line is my biggest problem at this time because the moles are using the fence line to travel and the dogs are digging massive ruts trying to get them.
Is there a pet safe effective way to either get rid of the moles and/or grubs which is what the moles are after that would also be economical to treat 50k square feet?
Just found this product,
Mole Scram . Never used it and just heard of it so do not know how effective or cost, but may be worth checking out.
Other advice on make your own repellent found
here as follows:
___
Moles and gophers can be controlled to some degree with hot pepper and castor oil products or home mixtures of the ingredients. Injecting the materials into the ground in the problem areas is more effective than spraying the surface. Planting castor beans around the perimeter of the garden can help. Devices that rattle or vibrate can also be part of the solution.
FORMULA
The formula for the castor-oil repellent can be made by using a blender to combine 1/4 cup of unrefined castor oil (can be purchased at most pharmacies) and 2 tablespoons of a dishwashing liquid. Blend the two together, add 6 tablespoons water, and blend again. Combine the concentrated mixture with water at a rate of 2 tablespoons of solution to 1 gallon of water. Use a watering can or sprayer to liberally apply the solution to areas where moles are active. The above mixture will cover approximately 300 square feet.
The repellent will be most effective where it can be watered into the moist soil surrounding surface tunnels made by moles. Areas that receive extensive irrigation will quickly loose the repellent to leaching. For best results, spray the entire area needing protection; moles will burrow under a perimeter treatment.
The repellent may need to be reapplied before moles depart. Once moles move elsewhere, the solution usually remains effective for 30 to 60 days
___
