headlamp washers were basically mandated by european regulations for xenon equipped cars. the death of HID and other factors the rules caused the rules to change. manufacturers took the liberty to send these systems straight to the garbage bin
What made this fuse blow..... sounds near impossible, but having the steering column cover loose. I noticed when the cover was loose, the steering wheel struggle to turn. Simply by putting it in place, zero issue whatsoever. Beyond my comprehension how this could be.
No, as the power steering worked until I took it off the trailer. I had resistance turning the wheel off the trailer. Yet, when I place this cover in its proper place (not let it hang)- the power steering works just fine. For seem reasons the pictures are not coming through, I will post them when they do.You don't think it was blown as a result of the flood?
No, I pulled her into the garage last night. Same issue. I had to hold up the gray felted cover showed in the lower portion of the picture to get the steering to turn, especially to the left. I suspect before I discovered this problem I was trying to work it loose, thus causing the 150 amp fuse to blow.Might the steering rack have gotten stuck due to sitting...your backing it off the trailer and freeing it was just enough to pop the fuse?
Yes, moved all the oil..... Was able to put a lot of it in a huge waterproof box that was super heavy duty, made it into three layers. Took some planning, but worked great. Yesterday I put it all on shelfs.Nice oil stash in images 4,5 & 7. Assuming you moved all that too?
Are you actually in a nut house on a nut farm, as your location shows?Are you actually in Utah, as your location shows?
I am in South Carolina, need to update my BITOG profile. I move every two to three years.Are you actually in Utah, as your location shows?
No idea what you are asking.... but if I win the lotto (I play once every few years), I will buy a pecan farm in West Texas, along with a home in California around a lot of wine making .....Are you actually in a nut house on a nut farm, as your location shows?![]()
Was addressing Jarlaxle. Look at his location.No idea what you are asking.... but if I win the lotto (I play once every few years), I will buy a pecan farm in West Texas, along with a home in California around a lot of wine making .....
Roughly how many acres would it take for a decent pecan farm? And of course wonder cost/acre.No idea what you are asking.... but if I win the lotto (I play once every few years), I will buy a pecan farm in West Texas, along with a home in California around a lot of wine making .....
Looking to partner with me? Out west (Texas and New Mexico), the very limited research I did says its all about irrigation- the trees need to be flooded with water systemically. I will pay for half your lotto tickets... as I don't purchase them often.Roughly how many acres would it take for a decent pecan farm? And of course wonder cost/acre.
