Kreen Update:
Changed the Shell Rotella T6/Formula Shell Oil blend out today. 8,200 miles were logged on this fill with Kreen used in the last 1K+ miles.
The oil/Kreen mixture came out very fast and hot after a 40 minute Highway drive at 60+ MPH.
The mixture was very thin and very black and still had the Kreen aroma to the oil. The same with the oil filter with the filter mag. The oil flowed out fast and thin when draining the Bosch D+, oversized Filter.
IMO…Kreen must have done its job very well with the color and consistency of the oil. The Kreen product must have found some carbon, varnish and Krud somewhere to come out so dark. I bet the engine is very clean inside after the Kreen.
I refilled with the Strauss Auto, Full Synthetic, 5w30, SM, GF-5 and another oversized filter…..the New Mobil 1, EP filter.
When filling the crankcase with the new oil I did notice something that did not happen before in my OCI’s.
The sump usually takes 6 quarts of oil with an oversized filter to bring it up to the full level but after the cleaning it now holds 6 and 2/3 quarts to reach the fill line on the dip stick.
IMO….the Kreen must have really thinned out the oil that usually remains up in the Galley’s and passage ways and that is why the oil drained out with a Fury when I opened up the hot drain plug on the pan. Nothing was left behind on this Oil Change and the usual oil that remains in the Galley’s and Passageways all drained down and out...during the oil change.
