Kitchen drain leak after disposal, pvc pipe
MD
So I did this drain plumbing about 11 years ago give or take. I had the assistance of a more experienced friend. I’ve personally never seen a pvc drain leak, but it’s definitely leaking from one of the joints that’s glued together.
Do I just re-do it all as it is, buy a 1.5” reamer and clean out at the y? Should there have been more threaded fittings so that this is more serviceable and wouldn’t be in the position of having to remove all this stuff to fix a leak?
I hate plumbing work. Every time I have a little drip. Which reminds me, a professional plumber calls a little leak, condensation. (A little joke I tell customers when they ask if I'm a plumbing "expert." I also say, "I'm an expert if you want a leak.") Maybe just a little extra glue around the joint may do the trick at stopping the leak?
If it is only leaking at that hard to reach joint, I would be hesitant to redo all of the PVC drain line. My suggestion would be to get the joint seam completely dry (e.g., paper towels and hair dryer) and apply the Rectorseal EP 200 epoxy putty found in the plumbing section of Home Depot, not with the glues and adhesives. It is not shown on HD's website, but carried in the brick and mortar stores. Amazon sells the 4 oz. version called EP 400. It will cure rock hard in 1 hour and is a permanent solution for plumbing leaks.
Before using epoxy, make sure the joint is dry. I would try appying some PVC cement where it leaks and let it migrate down into the joint. You got gravity working in your favor. It may seal , otherwise an epoxy such as those listed in above.
I’d be afraid epoxy or cement is just a temporary fix. If you think about it, there’s at least 3/8-1/2 inch glued joint there that was primed and glued and that failed. I can’t imagine a thin bead of epoxy or glue in that seam is enough to rely on. Maybe I’m wrong though.
The EP 200 putty is a permanent fix if you can get the joint surface dry. I repaired an exact same leak under my bathroom sink 12 years ago with a 1/4" bead of EP 200 and it has never leaked since. EP 200 is thick like modeling clay and bonds tenaciously, especially if you roughen up the surface with fine sandpaper.
That's is what is used for joining PVC pipe. Maybe the joint is stressed in some way, who knows? What do you have to lose by trying?
Although I'm just an average DIY-guy, I've done dozens of kitchen and bath remodels. I've never, ever used any type of glue or sealant on these PVC pipes. I start with a rough schematic to ensure my joints will be stress-free and simply hand-assemble/hand-tighten.
I'd personally re-do the whole thing, retaining the downpipe from the sink drain and replacing all the rest. The parts would be less than $40-$50 from the big-box store (probably much less)
Last year I installed a new cast iron sink in the kitchen and relocated the disposal from the left to the right side. One quick sketch and a trip to the store and she was done in no time. All new PVC simply hand-snugged. Not a drip.
Agreed! Avoid glued pipe under sinks whenever possible.
I would not try epoxy. This joint vibrates a lot from the food processor and it’s probably why it started leaking after so many years. The glue job didn’t penetrate all the way down and around. I don’t think epoxy will hold up to vibrations.
That’s why I mentioned checking if it’s not loose, it very well could be from years of vibrations and it could be an easy fix.
I wasn’t going to, but I’m not one to argue. Happy that a simple fix like that worked for anyone though.
I just got done taking it apart, the trap was sufficiently pushed up into the 90. I guess the glue / solvent weld just failed over time, or due to vibration. Nothing was stressed or bound. It was a ***** to get apart even though it was leaking. Took a lot of heat and gentle back and forth (I wanted to preserve as much plumbing as possible, I don’t have the bandwidth to figure out redo-ing all this right now). It’s worked this long, it can work again.
I seeked help on a plumbing forum and was blasted for the sideways wye. Maybe it’s wrong, but I haven’t had any problems, so for now it’s staying. That’d be the most problematic to fix as there’s barely any pipe to connect to. I know we had to use one of those rope saws to get in there and cut it as it was back then. Not that it’s impossible, but it’s not a project for right now.
Yeah, I would also keep the current setup if it worked for so long without issues.
Just make sure to clean up both male and female ends with some sand paper or a scotch pad. Then make sure you use a primer on both first, followed by the cement.
Rotate the elbow back and forth a little, as you press it in and then set it where you want it.
This should give you the strongest possible bond.
Only difference will be using trap adapters I think they’re called, so I can actually service the trap without heat and un-gluing things. I was surprised there wasn’t a clog in the trap somehow after that many years of use, whereas my bathroom sinks clog after 3 months or so (**** hairy shedding girls in my house!).
Gotta admit I don't understand your quandary. You can replace everything with new PVC for just a little time and money. Very easy job. And when it comes time to clean the drain and P-trap, it literally takes 20 seconds unscrew the connectors and take it apart (just put a small bucket underneath).
I'd re-route the disposal discharge to the sink's downpipe above the P-trap. You don't need a dedicated P-trap for the disposal...or that T-connector for that matter. All you need is a new P-trap, some elbows, and some straight pipe. All the new stuff is either flanged or gasketed for hand assembly. You can easily make yours look just like my setup I photographed. Home Depot or Lowes has everything you need in stock, and I'd bet it would be under 30 bucks.
I think you're making this much more difficult than it actually is.
Can't say that I've ever seen glued joints used under a sink. I have the best luck with the lightweight p-traps and tubes that have the compression fittings on the ends. If it were me, I would cut all that stuff out and convert over to the more user-friendly compression style. That clean out T may be handy, or it may serve no purpose at all, but it's another opportunity for a leak.
