Originally Posted By: tomcat27
The proper fix is to remove all of the current pipe and install the proper trap that you can dis-assemble. for your situation, I would be tempted to use glue/sealant on yours and try to patch it.
Exactly. You'd cut back to the stub from the wall and put a slip-in adapter there, like the one that is now on the tailpiece of the sink. Then use a prefab trap set or otherwise build out. In case of a clog or leak in the future you'd be able to take it all off at the slip-in adapter.
Properly glued PVC (though you don't have that, or it wouldn't be leaking) will not come unglued. There is a tool to cut an old pipe out of a fitting so the fitting can be reused, but trying to do that is not worth it here.
