Kitchen sink vent rusted leaking
Madiganistan/Chiraq
1956 ranch home with original galvanized/cast kitchen drain plumbing.
Filled the sink to the brim to soak some dishes as I unplugged the drain I hear water dripping in basement.
No leaking when water is running.
Dry under cabinets so it must be in wall.
I suspected hole rusted in the vent.
Cut open the wall in basement stairwell to check the pipes.
Found the threads at the top of the T to be completely gone. While heavy I could actually lift the galvanized pipe straight up a 1/4in. Repeated test with a full sink and water gushes out from the deteriorated joint.
So my issue Is 2 fold. Drain is partially clogged so that when drain pipe is completely full it backs up to the bad joint which under normal circumstances would just result in slower draining for a few seconds while the drain catches up. But now leaks out.
Super ghetto fix would be to just rod the drain then clean and JB weld the the joint together. In reality this would probably work for a long time.
I'm planning on cutting back the metal pipe near main line and running new pvc from the sink.
The slow draining is caused by a crappy initial plumbing job that has a low spot in the plumbing and actually goes uphill about an inch before going straight horizontal.
I could potentially cut the vent in attic and pull the old pipe up and out of wall. Then drop in new PVC or just cut it just above the T and put a fernco.
Franklin County, PA
You've already got the wall open, might as well do the PVC replacement now. Couple of Fernco's and PVC and you're in business. Be sure to support the vent, don't want it to fall down when you have it apart. I've had to do this to the old galvanized plumbing in my house; while not leaking the pipes were completely gunked up. Wasn't worth my time to snake it out.
Long Island, N.Y.
I see no "P-Trap" in your drawing around the Kitchen sink......Is there one there? If not, your letting sewer gas enter your home.
Anyway, I have had the same thing happen to me at my residence. I re-did it all in PVC. It was my first time doing pipe work and I was amazed at how easy it really was. Put a clean out at that low spot in the basement, and make sure your pitch is proper. Good Luck!
Brybo86
Madiganistan/Chiraq
Yes I have a p trap.
I agree that a clean out at the low spot elbow would be a good idea.
Did you go pvc all the way though the roof?
Near the beach in Delaware
I would go all PVC from roof to main drain. Do it once and be done.
In a prior house I had 4" copper drain pipe. There were sections where the copper had just corroded away in the middle of a run. The were holes through the pipe. I had as much as they could get to replaced with PVC.
MI
Are you going to have to change the roof flashing? If so, I might be tempted to cobble it together until better weather.
I agree with others to switch everything to PVC and be done with it.
Brybo86
Madiganistan/Chiraq
I dont think I will have to change anything outside
Looks like this from outside, pipe fits inside the cap thing
if for some reason I can't pull the old pipe out of that cap I'll just cut it close and use a rubber fernco to link
Under the Hood
Another good reason to:
1) Have plumbing exposed as much as possible
2) Inspect once a year
Brybo86, good luck.
I've had PVC drains & vents in my house (32 yo) and never a problem.
manicrodder
$50 site donor 2022
Cedar City Utah
Brybo86, good luck.
Here's a thought. The system is known as a Durham with the mixed steel fittings. If the pipe is supported you can cut out the tee and use Band-Aids which is trade talk for neoprene stainless clamp fittings.
Cast iron utilizes these clamps for typical installations today replacing lead and oakem joints.
Brybo86
Madiganistan/Chiraq
Finally got around to fixing this.
Now just have to patch a bunch of drywall.
pa
for sure poor plumbing + electrics show their ugly head years later $$$$, even newer homes quickly built can have issues + anything hidden in walls, floors or underground are the biggest PITA!! my older home started having sewer problems after 50 or so years as the terracotta pipes used had NOTHING in the joints + the grape vine i tore out eventually grew to the moist seepage, two rentals for a snake then a proper fix i dug it out + replaced with PVC, luckily not very deep but removing concrete steps was a bit of work. like any DIY it takes longer than a pro but $$$$$ cheaper as i was young + my usual energetic self!!
