Kitchen drain leak after disposal, pvc pipe
MD
So I did this drain plumbing about 11 years ago give or take. I had the assistance of a more experienced friend. I’ve personally never seen a pvc drain leak, but it’s definitely leaking from one of the joints that’s glued together.
Do I just re-do it all as it is, buy a 1.5” reamer and clean out at the y? Should there have been more threaded fittings so that this is more serviceable and wouldn’t be in the position of having to remove all this stuff to fix a leak?
I hate plumbing work. Every time I have a little drip. Which reminds me, a professional plumber calls a little leak, condensation. (A little joke I tell customers when they ask if I'm a plumbing "expert." I also say, "I'm an expert if you want a leak.") Maybe just a little extra glue around the joint may do the trick at stopping the leak?
If it is only leaking at that hard to reach joint, I would be hesitant to redo all of the PVC drain line. My suggestion would be to get the joint seam completely dry (e.g., paper towels and hair dryer) and apply the Rectorseal EP 200 epoxy putty found in the plumbing section of Home Depot, not with the glues and adhesives. It is not shown on HD's website, but carried in the brick and mortar stores. Amazon sells the 4 oz. version called EP 400. It will cure rock hard in 1 hour and is a permanent solution for plumbing leaks.
Before using epoxy, make sure the joint is dry. I would try appying some PVC cement where it leaks and let it migrate down into the joint. You got gravity working in your favor. It may seal , otherwise an epoxy such as those listed in above.
I’d be afraid epoxy or cement is just a temporary fix. If you think about it, there’s at least 3/8-1/2 inch glued joint there that was primed and glued and that failed. I can’t imagine a thin bead of epoxy or glue in that seam is enough to rely on. Maybe I’m wrong though.
The EP 200 putty is a permanent fix if you can get the joint surface dry. I repaired an exact same leak under my bathroom sink 12 years ago with a 1/4" bead of EP 200 and it has never leaked since. EP 200 is thick like modeling clay and bonds tenaciously, especially if you roughen up the surface with fine sandpaper.
That's is what is used for joining PVC pipe. Maybe the joint is stressed in some way, who knows? What do you have to lose by trying?
Although I'm just an average DIY-guy, I've done dozens of kitchen and bath remodels. I've never, ever used any type of glue or sealant on these PVC pipes. I start with a rough schematic to ensure my joints will be stress-free and simply hand-assemble/hand-tighten.
I'd personally re-do the whole thing, retaining the downpipe from the sink drain and replacing all the rest. The parts would be less than $40-$50 from the big-box store (probably much less)
Last year I installed a new cast iron sink in the kitchen and relocated the disposal from the left to the right side. One quick sketch and a trip to the store and she was done in no time. All new PVC simply hand-snugged. Not a drip.
Agreed! Avoid glued pipe under sinks whenever possible.
I would not try epoxy. This joint vibrates a lot from the food processor and it’s probably why it started leaking after so many years. The glue job didn’t penetrate all the way down and around. I don’t think epoxy will hold up to vibrations.
That’s why I mentioned checking if it’s not loose, it very well could be from years of vibrations and it could be an easy fix.
