MMO is one of the few "cleaners" gentle enough that I would put it in one of my Bimmers engines, but it is absolutely not going to increase the lubricity of a good oil, especially a good "consumers choice" like M1 0w40, or a boutique track-quality oil like Redline 0/5w40 (what I use).
The only possible way I ssee it doing anything to help protect the engine, aside from its mild cleaning ability (frankly, I have gotten rid of sludge faster using RL, an ester base, than with MMO mixed with a Group 3/Group 4 mix like M1 0w40 in as high a concentration as 20 percent), is that it MIGHT reduce startup wear a little bit in negative temperatures (Fahrenheit).
Frankly, outside of Alaska and a few other places, the relative amount of negative degree Fahrenheit starts to 32F+ starts is so great that for me, I don't think it's worth the possible negatives to run it constantly.
To be clear, I am saying that I see a benefit for cleaning, and for use in gas, but that a clean engine running a top of the line oil will have absolutely no benefit, leaving the only possible outcomes to be either no effects, or the significantly more likely negative effects. Will most people ever see the negative? No, not if it shortens engine life from 300k to 250k, for example, but I would absolutely be livid if I bought a vehicle and the PO didn't disclose that they'd used a bazillion additives, or even just one but constantly. In fact, that happened with my former 1990 E30 Hartge 3.8, a very rare car (a 325is w the the 325is' 2.5L M20 and 5MT pulled and the Euro M5/M6 S38B38 and 6MT swapped in, custom exhaust and Supersprint made headers + Gruppe-N carbon intake manifold + hotter cams and tuned, a full suspension upgrade and LSD, Hartge full interior, and a unique to the car body w F+R bumpers, skirts, widened fenders, front aero lip and rear diffuser, Hartge wing/M3 Mirrors, Recaro's made to spec for Hartge, 3-spoke modified EVO3 steering wheel, Brembo-sourced brakes w 4-piston 324x34mm 2pc front and 2-piston 318x28mm 2pcrear setup, and Hartge "Race" Forged Multipiece Wheels in 17x8 and 17x9... Only a ccouple dozen were made, this was a beautiful Henna Red over a mix of Alcantara and Leather with just 38k miles). I got it, after 5 months of waiting, and the outside was flawless, the interior had not even a crease in the seats, even the underbody and engine bay were flawless.
However, when my mechanic and I opened up the motor to ensure timing was correct, there was a lot of gunk, and it wasn't sludge, in the motor. It felt a lot like what you would imagine burnt stopleak stuff to feel like, but it had that unique smell of MMO.
I called the PO and demanded to know what was put in it, because the ironically meticulously kept and insanely extensive maintenance and records show nothing to explain it.
The response was that a number of products were used to try to quiet down the lifter/valve tick. This included MMO, 3 types of Lucas stuff, and quite literally almost a dozen more. Apparently, the shop doing maintenance said that there's no way that it could be a timing issue, as the valves didn't need adjustment for another 20k miles.
Well, it turns out that after we cleaned up the whole engine, we found that the timing had been off by almost 6 degrees!
The price fortthe car was amended in consideration of this, and I hold no grudge.
I just know that if I hear a seller mention anything beyond the typical Techron/SI-1/etc, I ask for either a sample from the car and send for UOA, or make a deal about cost of a much more extensive PPI.
The Hartge, well, it was one of the most fun cars I've ever owned, up there with a first generation MR2 Supercharged (w track suspension, 15x7 and 15x8 BBS Mesh 3pc wheels (9.5lbs), a giant induction system, and equal length tubular headers into a single 3" mandrel bent exhaust pipe w only one resonator to quiet it exhaust system, shortened pulley for an extra 4.5psi, and front/rear cross-chassis bracing and behind the seats an X-brace; oh, and the already featherweight car had a further 119lbs removed.. 239bhp and 1835lbs, for $4k!).
I regret selling it oh so much...
But, sorry for the reminiscing...
The point is that there's no reason to do what you are wanting to do, as every benefit you expect from this would be had a hundred fold over by simply switching to a proper oil weight.
For true year round use in my BMW's that see year round use, I use 0w40 and occasionally 0w30, never once has it given me any issues.
The only time I use anything above a 5w is with either my E46 M3/E39 M5 and the recommended 10w60 TWS (although I have had some odd results with it, and believe the formula has changed again, to favor the S65 V8 and S85 V10 and newer engines; consequently, I have been using mostly RL 5-10w50 and have had phenomenal results), and with my 328Ci on the track, where I run RL racing spec oil in a 10w40 (no VII/VIM used apparently).
I would not be running a 10w anything in an M52tu/M54/N52, not for daily use. The rod bearings suffer a lot of unnecessary wear as a result of too heavy an oil.
