Mainia
Since the Hyundai Kona is a world car, it holds 4 liters in US form.I poured the dumped oil into a measuring bucket. The oil capacity was 3.7 qrts. Just about 5 qrts came out.
3.7 quarts in the sump is a reasonable number, then, if you are omitting the oil in the filter.Since the Hyundai Kona is a world car, it holds 4 liters in US form.
UOA? could you post them or link to them? might help the skepticism in here.I would throw some Mobil 1 ESP I still have in, but when I was playing oil brand swap back at the beginning I got a high lead 70 ppm from changing brands and add packs the guy at Polaris said. They see it from time to time. He wanted to see me stay with the same oil for three oil changes and said we will see this come down, as it did. He raced Hyundai's and builds motors so they tossed me over to him because he was their Hyundai guy.
No one doubts his story.I wouldn’t discount what the OP experiencing. He told us what he is experiencing with using a different oil. There’s no reason to believe he’s being untruthful.
It's the leap from observation to conclusion that is doubtful.
Since the title of the thread is, in fact, that specious conclusion, it has everyone's attention.
The oil he was using previously, M1 ESP, is specifically designed for TGDI and was already formulated to avoid LSPI long before it became standard.It is quite possible that the oils he was using before were causing light knocking and the ECM stepped in to adjust the fuel and spark timing.
Part of the SN Plus oil LSPI testing was to improve fuel economy of current T-GDI engines via avoiding LSPI situations.
Again, there’s no reason not to believe the OP or question his antics.
It might not have been enough for his application.
OP- if you are seeing improvement in your fuel dilution then that’s all that matters. Many folks here aren’t going to believe you and that’s okay. Again, I noticed an improvement when I switched to the SN Plus oils on my GDI engine. Oil didn’t darken as much as before and the fuel smell was greatly diminished (Same oil change interval). I mentioned it this past summer and I got talked down because of it as well. There’s a lot more to motor oil than people here would like to admit and the technology needed for it to work well in today’s engines is like no other we’ve seen before.
Maybe, but your if it changed over time. Oil that always raised in amount. Then an oil change, waited 2 weeks and what nrmallyI’m highly skeptical of the claim that a change in oil brand resulted in lower fuel dilution.
The source of dilution, your DI injectors, has remained unchanged. So, how could the oil affect the amount of gasoline in your oil? You offer a thin guess, but it’s both thin (ring sealing?) and a guess.
Worse, you impute lower dilution based on oil level measurement.
Because the oil level didn’t rise as much, you’re not getting gasoline in the oil? That’s a wild assumption. You are more likely to be getting the same amount of fuel, but some, as yet unknown, factor is causing the oil to be consumed.
Therefore, same dilution, but no change in level.
Your “conclusion” is premature, when no UOA has been done and many alternative explanations exist.
UOA? could you post them or link to them? might help the skepticism in here.YAWN
Because right now this thread resembles a boy racer who just discovered the Redline Aisle at Summit Racing.
Lots of accusations and opinions from OP with no facts.
saying "YAWN YAWN CONSPIRACY YAWN"
doesnt change anything.
Turbo diesel car, and turbo gas car. But it is marginal oil since it is not API and TGDI approved. And is over ten years old.The oil he switched to is a formula that's more than a decade old, it's not API SP, it's not API anything, it's not even an API approved product, and it most certainly wasn't reformulated for TGDI applications.
4.5 litres in europeSince the Hyundai Kona is a world car, it holds 4 liters in US form.
2018 Hyundai Tucson 1.6 AWD never had a problem with gas in the oil with normal driving using whatever 5W-30 synthetic that was on sale.
A slightly bigger oil pan? 4 bottles of ESP (1 liter bottles) fill it a hair over full in the US model.4.5 litres in europe
Yea, but MoleKule said his only thinking is the Ester could be sealing the rings better. Who knows????There is no oil that changes the mechanical function of how a vehicle injects fuel. The Kona may have slowed the fuel dump on its own. Either way, that's great news.
No crap, this is not politics.........OH wait.........?I wouldn’t discount what the OP experiencing. He told us what he is experiencing with using a different oil. There’s no reason to believe he’s being untruthful.
Not entirely true. SN Plus oils help mitigate LSPI. Current GDI/TGDI engines have logic in the ECM that changes fuel/ignition timing in situations where LSPI may occur. Most OEM’s control and try to prevent LSPI by injecting more fuel into the cylinders to help curb LSPI. This lowers fuel economy and contributes to fuel dilution. If an engine oil is helping to keep abnormal combustion at bay, the ECM doesn’t have to resort to changing fuel/ignition timing nor dump more fuel into the cylinders.There is no oil that changes the mechanical function of how a vehicle injects fuel. The Kona may have slowed the fuel dump on its own. Either way, that's great news.
As I noted earlier, this isn't an SN Plus oil, it's not even SN or SM, it's "recommended for" SN applications and the PDS was last updated in 2017:Not entirely true. SN Plus oils help mitigate LSPI. Current GDI/TGDI engines have logic in the ECM that changes fuel/ignition timing in situations where LSPI may occur. Most OEM’s control and try to prevent LSPI by injecting more fuel into the cylinders to help curb LSPI. This lowers fuel economy and contributes to fuel dilution. If an engine oil is helping to keep abnormal combustion at bay, the ECM doesn’t have to resort to changing fuel/ignition timing nor dump more fuel into the cylinders.
or a shorter dipstick, who knows. The non-turbo takes 3.6 litresA slightly bigger oil pan? 4 bottles of ESP (1 liter bottles) fill it a hair over full in the US model.
