My mom just bought an 09 Liberty. I know that the 3.7L engines used 51516 Wix filters, but for 09 it looks like they use a 57045. I don't know what the difference is, and the Wix website is not working. Anyone know what is different and why they changed? I see the thread size is the main difference. I wonder why they changed?
Edit. The Site is working now...
Part Number: 57045
UPC Number: 765809570450
Principal Application: Various Dodge, Jeep, Mitsubushi w/ 3.7L Engines (09)
All Applications
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.782
Outer Diameter Top: 2.939
Outer Diameter Bottom: Closed
Thread Size: 22X1.5 MM
By-Pass Valve Setting-PSI: 8
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20/75=10/20/25
Nominal Micron Rating: 21
Gasket Diameters
Number O.D. I.D. Thk.
Attached 2.741 2.458 0.238
Part Number: 51516
UPC Number: 765809515161
Principal Application: Ford/Lincoln/Mercury (81-09), Chrysler/Jeep/Mitsubishi (02-09), Mazda Trucks (94-07)
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Outer Diameter Top: 2.921
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Beta Ratio: 2/20=14/31
Burst Pressure-PSI: 275
Max Flow Rate: 7-9 GPM
Gasket Diameters
Attached 2.734 2.430 0.226
Part Number: 57045
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.782
Gasket Diameters
Part Number: 51516
All Applications
Service: Lube
Type: Full Flow
Media: Paper
Height: 4.828
Thread Size: 3/4-16
Gasket Diameters
