Which filter would you use? Filter A is what the OEM filter crosses to, both have the same beta ratio, by-pass vale setting, anti-drain valves, etc.
But Filter B has a micron rating of 5 vs 21 for Filter A, plus its a little longer. They Do & Will interchange, I have run Filter B on the engine for 450 hours, changing oil & filter every 200 Hrs w/ No Problems.
So which would you use? the OEM interchange Filter A or Filter B ?? BTW Filter B is cheaper, LOL
FILTER A
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Cellulose
Height: 2.98 (76)*
Outer Diameter Top: 2.69 (68)*
Outer Diameter Bottom: Closed:
Thread Size: 3/4-16
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=6/20
Burst Pressure-PSI: 400
Max Flow Rate: 7-9 GPM
Nominal Micron Rating: 21
FILTER B
Service: Lube
Type: Full Flow
Media: Synthetic
Height: 3.404 (86)*
Outer Diameter Top: 2.921 (74)*
Thread Size: 3/4-16
Nominal Micron Rating: 5
