I have a Nissan 350z and was wondering which of these 2 filters would be the best choice? Wix website says I should use 51365, but the maxima uses the 51356 (same engine pretty much).
Part Number: 51365
Type: Full Flow
Media: Paper
Height: 2.577
Outer Diameter Top: 2.685
Outer Diameter Bottom: Closed
Thread Size: 20X1.5 MM
By-Pass Valve Setting-PSI: 8-11
Anti-Drain Back Valve: Yes
Beta Ratio: 2/20=15/22
Burst Pressure-PSI: 300
Max Flow Rate: 9-11 GPM
Nominal Micron Rating: 19
Part Number: 51356
Style: Spin-On Lube Filter
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
Beta Ratio: 2/20=6/19
Burst Pressure-PSI: 363
Part Number: 51365
Type: Full Flow
Media: Paper
Height: 2.577
Part Number: 51356
Service: Lube
Type: Full Flow
Media: Paper
Height: 3.402
