Looking at two different filters from wix for hydro-static tractor, I find one that is cross referenced from Donaldson, and another from crossing the oem part number. They are both the same in fitment, however, the beta ratio and micron ratings are different. Which filter would be the best? .....,,,,,,,,,...,,,,,.wix 51455 http://www.wixfilters.com/Lookup/PartDetails.aspx?Part=61853 Part Number: 51455
UPC Number: 765809514553
Style: Spin-On Hydraulic Filter
Service: Hydraulic
Type: Full Flow
Media: Microglass
Height: 6.02 (153)*
Outer Diameter Top: 3.81 (97)*
Outer Diameter Bottom: Closed:
Thread Size: 1 3/8-12
By-Pass Valve Setting-PSI: None
Beta Ratio: 2/20=4/10
Burst Pressure-PSI: 1000
Max Flow Rate: 24-28 GPM
Nominal Micron Rating: 10 ................,,,,,,,,,,,,,,,,,,,,...................,,,,,,,,,,,..........................,,,,,,,,,,,..................,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,,................,,,,,,,,,,,,,,,,,,,...................,,,,,,,,,,,,,,,,,................ wix 51456 http://www.wixfilters.com/Lookup/PartDetails.aspx?Part=61987 Part Number: 51456
UPC Number: 765809514560
Service: Hydraulic
Type: Full Flow
Media: Microglass
Height: 6.02 (153)*
Beta Ratio: 2/20/75=9/23/30
Nominal Micron Rating: 9
Service: Hydraulic
Type: Full Flow
Media: Microglass
Height: 6.02 (153)*
Service: Hydraulic
Type: Full Flow
Media: Microglass
Height: 6.02 (153)*
