Originally Posted By: edyvw
Originally Posted By: VNTS
There really isnt much difference on WK2 maintenance with 3.6 or 5.7, both fairly easy.
Diffs have fill/ drain plugs, ditto t-case, oil changes easy, only PITA is the ZF 8spd .
pushing 40k on hemi Overland, no issues, great SUV with quadra drive and air suspension
Would like to hear this explanation?
The ZF 8-Speed isn't really a PITA, as much as it is expensive to do a fluid and filter change. The filter is more or less "built into" the pan. Which in essence makes the pan pretty much a disposable item. So when you do a fluid and filter change, you're stuck with buying a new pan and filter assembly.
The dealer wants $47.00 a quart for this fluid. (I believe it is a 9 or 10 quart capacity). I don't think it's available anywhere else. And even if it is, it's meaningless if you have the job done at the dealer. The filter and pan assembly runs $335.00 To $378.55. So when you add up the fluid, parts, and labor cost, you're looking at anywhere from $824.00 to $1105.00 (before taxes) to do a transmission drain and flush for a ZF 8-Speed automatic. (They run around $4K to replace).
https://www.oildepot.ca/dodge-dealer-home-of-1000-atf-flush/
All the 8-Speed ZF automatics are pretty much identical regardless if they're in a Jeep, Dodge, Chrysler, or a Ram truck. By comparison it cost me $800.00 and change to have my 1991 Ford 4-Speed Automatic Overdrive automatic transmission completely rebuilt in my 1991 Mustang when I had it.
