Is this tree limb diseased?
Winnipeg MB CA
Any arborists here? This American Elm is in our back yard. I try to prune it back every two or three years to keep it a manageable size, and to keep it healthy. This one limb has a darker core. Is this normal, or should I prune it back until the dark part is gone? Thanks in advance!
I'd prob leave it as is but trim off all those suckers/small branches that you don't want on the tree. That should help it thrive. There is an arborist on here from MI but forget his exact name. I'll go look for it.
edit: ok found him, he's a research forester at a large university for 40 years. His name is "doitmyself". Maybe send him a pm if he doesn't see this. He's very nice if you want to send him one. In other words he won't bite your head off, lol.
Yes, PM doitmyself for more info. He's an expert on this. Tell him I sent you.
There are good books on pruning trees available in the library or on line. I've read many of them.
I see a wire in the picture. Is it close to the tree? This could be a problem in wind storms or if dead branches fall.
I used to have a couple russian elms. They were nasty for dropping dead branches. They twice took out my lines.
I am not that Arborist but am an Arborist, CTE Certified Tree Expert, Bachelors in Plant Biology, graduate Landscape Design, licensed Pesticides, and ......
American Elms are dying from Dutch Elm disease though there are now some resistant varieties.
The dark you see is the Heartwood which is older xylem that is dead. It provides support for the tree. Its dark because of unused stored sugar, dyes, and oils. Active Xylem surrounds the heartwood and is called Sapwood. This carries the nutrients and water from the roots to the leaves. As the tree ages and becomes larger in diameter, the formerly active xylem closest to the outer heartwood dies and becomes the new heartwood.
You are not helping your tree keeping it healthier by cutting these branches like this. You are giving insects, bacteria, viruses an opening in the tree to enter. When you cut a branch, you must cut it at a bud, this is the active growth tissue. It can then heal forming a scar like seal over the wound. It should be cut fairly close to the tree. At the correct point at a branch joint, you will see rings, you want to make your cut just a hair on the last growth ring.i
Next, by cutting branches, you are reducing the number of leaves the tree has to make food for the tree through photosynthesis thus weakening the tree by starvation.
You also create sucker branches which have soft bark allowing entrance of organisms.
And, it takes a lot of energy to produce new branches, so by cutting, you are starving the tree and forcing the tree to use more of its depleting food reserves.
Trees need water and fertilizer however fertilizing a dying or a tree under stress can accelerate its decline.
You nailed it, and then some, JLawrence08648. The picture looks like he is topping the tree, which you already pointed out is going to open it up to even more risks. https://www.google.com/search?q=topping+a+tree&ie=utf-8&oe=utf-8&client=firefox-b-1 I imagine it's probably a last ditch effort to retain a tree that has outgrown its space.
Since this is your area of expertise, maybe we should split the consulting fee 70/30? Let's see, 30% of nothing for me...........
