Truck is a 2020 Tundra with 58k miles. Meticulously maintained and just had 4x4 fluids serviced at 50k miles. I use 4Hi pretty often and every month or two initiate 4-Lo to make sure the actuator doesn't stick.
There were a bunch of cars in my driveway and I didn't want to back all the way down the long driveway so ended up backing up into about 8" of snow covered in a crust of ice. I got a little further off the driveway than intended (usually try and keep front tire on pavement) and got stuck in 2WD. I popped it into 4Hi and gave some gas and all four wheels spun. I decided to put it neutral and engage 4Lo. I gave it a little gas and the dash lit up like a Christmas tree with both 4Hi and 4Lo flashing, ABS light was on, Traction light was on, Pre-collision system malfunction, Drive start control malfunction, Trailer break error.
My wife just had a total knee replacement and she needed to go to PT so I left it for an hour and when I came back and started truck same lights are on and it will not go into 4WD. It's now stuck in the front yard and it's going to be at least until the middle of next week before I will be able to get it out with only 2WD working. That's not a problem as my wife can't drive for awhile anyway but wondering if anyone has any guidance?
