Hot take: 0W20 has been mainstream for nearly two decades worldwide, and has made a good reputation for itself as “good enough” for engine wear protection. 5W30 has been around much longer and has much more evidence to support its superior protection under higher ambient and engine temps, and withstanding more of a beating.
When it comes down to a reputable brand like the Valvoline Advanced that I use, and the only difference is going to be going with the manufacturer “recommendation” (largely imposed for cafe standards to eek out half a mpg more), I will choose 5w30 over 0w20 every time for engine protection.
That being said, I do live in a very cold climate and I need low temperature protection, so I do use 0W30 in winter as a compromise.
Simple answer: if you use what the manufacturer recommends and what it says in the manual/on the oil cap, and observe responsible change intervals, and treat the engine right in general, there’s a very high likelihood your engine will have a good long life. If you want to take extra precautions to hopefully make it last even longer, 5 or 0W30 is also a very good option that will certainly add more protection, not less.
