Is synthetic worth it
First off, with any effort, you can pay very little for syn.
I just put Mobil 1 0w30 in my '99 Accord, which cost $12.00/5 qts after MIR, or $2.40/qt. If you believe Mobil's figures, the oil will save enough fuel over even a 5K run to pay for itself.
For the Subaru, I like GC.
You can pick it up for ~$4.50/qt from PB or AZ when they run an oil change special.
If you like PP, I have three 5 qt jugs at $1.00/qt after MIR.
I also have a few cases from Meijer at $1.49/qt on clearance.
So, while I like syn oil for a number of reasons, I also make a practice of finding it cheap.
Originally Posted By: rewote500
Alot of Dodge 2.7L engines fail at around 70K miles....See Below
http://www.carcomplaints.com/Dodge/Intrepid/2002/engine/index.shtml
I have used Mobil 1 5w30 (yes the supposed worst one) with this car forever. At 153K I pulled the valve covers off and it was clean as a whistle. No I cannot prove it but judging by other experiences with this car the synthetic oil was a good investment.
The quote "the worst one" is stange. As you, a friend uses Mobil 1 5w30 in his 2000 Taurus Duratech and has 310,000 miles with 10,000 mile OCIs. He also claims it is very clean.
i dont care what anyone says 10,000 miles is too long on any oil there is the dust and dirt factor that gets through your air filter and oil filter, Condensation, acid and all sorts of other things such as the unburned fuel and additives in the fuel etc.
oil is cheap compared to an engine.
use the oil of your choice with a sm rating go maximum 5000 on dino and 7500 on synthetic Maximum
If you want to save money on oil and go 10,000 miles than when you need an engine spend that savings here..
I'll take that under consideration for 2 seconds. Really I have done 10,000 mile OCIs for 32 years in many differant engines with great success.
That's not based on science at all. I know you "don't care what anyone says", but that doesn't make your opinion fact.
Have you considered that some people do 10k in 3-4 months? There was a time when I was doing 30k-40k miles per year.
Originally Posted By: Gary Allan
Sure, but it assumes that they'll rightly use the OLM to some sensible level with conventional. If the synthetic is the ONLY way the owner will follow the OLM to near the end of the countdown, is it wasting "as much"??? What if "fear factor", due to either the time or mileage expired, forced them to swap conventional out at 45%???
It could be a lot of wasted money and resources.
What if someone is a 3k/3m prisoner and a synthetic allows them the confidence to go 6k/6m?
Either way Gary, I agree 100% with you, however I wanted to give perspective on the other side is all. I also noted I'm running synthetic as well. In reality however the circumstance I gave is a valid one, and it may only be true for a small percentage of people using synthetic while running a conventional OLM. I wonder in the real world what oil changes are really like, how many miles, etc etc. I almost think that BITOG takes a snapshot of the public in that people will over maintain an engine by changing the oil more often than being under maintained by not changing the oil enough.
When it comes down to it we all waste plenty, and you, nor anyone else on here will do much in changing anyone's mind about synthetic, conventional etc, they read information posted, then make the choice.
On the 3k OCI prisoner it would make no difference as they are still the same as a 5k person, that is if either doubles the OCI on synthetic. However what I was directing my post more at is if the OLM is set up to run out to 8k on conventional I don't think many would double that on synthetic... so if they stretch it out to even 10k your not gaining enough to compensate for the price difference between synthetic, and conventional. My Honda calls for 7500 mile OCI, I shoot for 15k on synthetic, and fall short pretty much every time, however as has been stated it gives my several things in my favor. If I don't have time, it's messy weather etc I can wait.
All my typing, my opinion is people are going to do what they are no matter what conventional or synthetic. Double the oci be it 5k or 3k makes no difference if they double it using synthetic, however we (myself included) are reaching out there to grasp false hope when manufactures set up OLM (spending large sums of money in R&D on the OLM) and we consumers think we know better thane the manufactures, choose to use synthetic, and run out the OLM the same. Gary would you agree with me many late model OLM set up for conventional are run out using synthetic for the "safety not trusting the manufacture" and the OLM is still not run out ?
I have run 10,000 OCI on conventional !! Not on purpose mind you, however I have, and I would bet that I could do it regular with no harm to my engine, nor hurt the life of it. I can't imagine a manufacture setting up OCI lengths at 7500 miles (my Honda) and at 10K it would cause engine failure, nor lessen engine life. I know the manufactures have to have a safety threshold I don't think we are reaching conventional oil life using current OCI lengths, much less synthetics.... one huge problem is I'm not brave enough to be the one to test it LOL
I know that's why people do oil analysis, however I guess I'm to cheap, or it just does not interest me in doing so. I wonder one day will oil change be more of filter changes. If car manufactures had an easy way to change the oil filter without making a huge mess in doing so, drain off say 1/3 of sump while changing filter, then add oil, filter. This is what I see as the oil change of the future, I think we are going to see less, and less waste.. woes unto those seeking short OCI, I don't think it will be law, however I think it will be enforced with price of oil.
It may sound far fetched, however if a few items come into play. A OLM that monitored the oil in real time, and not driving habits set by mileage. It could be done, and any electronic gizmo like this would be expensive... that is until you spread the cost out over millions of cars, and profit of being green. Then have someone who changes oil to design the oil filter, and they method of changing it LOL not some engineer who looks at the engine before it's in the car/truck !!
Oh [censored], my 04 Stratus 2.7 just hit 72k..
The way I figure, synthetic costs 2x the price of dino at retail. For the same cost, will you get a better result with synthetic at 2x the interval of dino? I say no. I'll take dino at 5k over synthetic at 10k. Even moreso when you push the distance a lil higher, like 6k/12k or beyond. I don't wanna hear about filter cost, they are good for the same miles with either oil.
Believe what you want actually i like the way you think more people should think like you and do 10,000 mile plus oil changes.. That would further improve my business please spread the word..
Not based on science? I don't know what science you base your facts on and who was involved in deciding your "science" but 18+ years in my machine shop doing nothing except engines has taught me that you must change your oil more often than what your "science" tells you if you want a really long life for your engine.
Well Pablo that makes my opinion fact to me and thats all that counts.
However if you know of some "magic" oil that is not affected by the things i have mentioned than maybe i have overlooked something, but i personally dont think so.
crazyoildude, you have actually overlooked something.
Sorry to inform you about it, tearing down your perfect image of what to expect from an oil.
You should try to look at higher quality synthetic, not the group 3.
The fact is that not all people have time to take their engine into a shop and change their oil every 3000 miles. Some people don't even have time to do it themselves for that matter. Some people do 3000 miles in 2 weeks, some in 2 years.
If you do 10,000 miles in less than 3 months and your driving is mostly highway, I don't see how you'll have so much wear on a synthetic oil that it would be a problem compared to most cases where people do 3,000 miles in 6 months doing 2 miles commutes a day.
crazyoildude, your shop experience doing engines gives you valuable knowledge but your knowledge is restricted to people who have had problems. People who don't have problems don't go to you unless you failed to mention something here.
I have no doubt at all you have seen some real cases where people went way past needing an oil change. Of course I know it happens. What I highly doubt is that those engines were run on good synthetic oil and they were at 10,001 mile OCI's.
The logic flaw I challenge is that the contaminants, the very nasties that you see, and clean somehow come from the outside world, so to speak. I say, and the science shows, these come from the oil itself breaking down. They aren't even close to primarily coming from unfiltered air, water, or even partially oxidized fuel - they are from the oil breaking down. Yes - the oil is breaking down from oxidation (heat/burning) and is challenged with dealing with fuel, water, particulate, etc. However, it a well made oil can deal with these "things" much longer than is assumed.
I think even the many, many years of synthetic oil used oil analysis posted here don't show even group III breaking down at less than 10K miles, and there certainly quite a few 12K+ used oil analysis, in a variety of engines and abusive situations - guess what? Oil in fine shape, engines clean.
The "things" you mentioned are real, but they aren't magic, they aren't monsters - they do happen, but not at the rapid uncontrolled rate some of the oil marketers want you to think with their sludge dump commercials and 3K OCI's. Using a good oil, knowing your engine and conditions will lead to a "really long life for your engine."
I really applaud someone such as yourself taking the time to learn about oil. It's actually rare - some shop owners just have their mind made up, not open to thoughts about tribology.
It would take me almost 20 years to get 200K...so 900.00 bucks saved. Its alot of money but is it really worth it to go cheap.
You will notice in my signature it say I change my oil at 10K. If there were enough room to type everything I wanted to say, it would of said 10K or 12 months, which ever comes first. I will be changing this spring at the 12 month mark, but the oil in the car will only have around 5.5K on it. If I get to 10K in 3,4,5, or 6 months, it gets changed at 10K.
My wife's 06 Corolla uses PP and I have been dumping it every 5k. Based on what you guys are saying, going 10k on that oil along with the oil filter going that long is okay? She puts "regular" amount of miles on it, where if I were to think about going 10k on it, it would probably take 10 months for that to happen. My car on the other hand, I just change it out every 5k with regular oil, being that since I have a take home car, I don't drive my personal car a lot. So are you guys saying that I wouldn't encounter any more possibility of sludge or increased engine wear by going an extra 5k on that synthetic? I guess I need to keep up with the times and believe that.
Originally Posted By: GROUCHO MARX
Try Super Tech synthetic
You know, I was considering this option then I went to WalMart and found that Rotella T6 synthetic 5w40 was only $2.50 more than the SuperTech and could not justify using the SuperTech when such a great product was only a little more.
