Originally Posted By: AEHaas
I would guess that at a sump oil temperature of 302 F there would be no measurable difference in pressure by normal automotive sensing devices. The oil delivered to the oil filter (the usual measuring site) would have a viscosity of 3 cS for a 30 grade oil and 4 cS for a 40 grade oil. The difference is only 1 cS.
Measuring the difference in pressures at 104 F would also be difficult. If there was 1 cS difference in the range of 67 to 68 cS, could any automotive sensor tell between the two viscosities? I say no.
Then again, my belief is that pressure only serves the function of delivering oil to the bearing surfaces. It has no function regarding the separation of parts within the bearing.
aehaas
You are confusing HTHS viscosity and kinematic viscosity. You should know this, having posted articles online that you wrote on viscosity. I'll probably keep busting your chops until you take down that misinformation that is posted online. It's been years and you've been shown somewhat politely numerous times that you are confused so you had your chances to take it down without great insult.
Also, sump temperature of 302F is not why HTHS is measured at a temperature of 302F. Sump temperatures better not be 302F but oil gets that hot and hotter routinely in certain parts of engines.
Finally, let's suppose that a value of something does change from 4 to 3. In your example, you said the difference is 1 and implied it's not big. It is the percent difference that matters: 25%, which is very significant.
Fast VW, see Slide 9 in this presentation.
http://www.astmtmc.cmu.edu/docs/diesel/hdeocp/minutes/2001/hdeocp.2001-05-25/052501ATT12.PDF
It's the best data I found (though doesn't directly answer the question posed) in the time I spent looking. There is some scatter in the data of course. The different oils have different shear stabilities indicated by SSI: Shear Stability Index, where lower number is more shear stable. Two oils with different HTHS but same initial kinematic viscosity (KV) at 100C will likely have different shear stabilities. During use, the one with lower HTHS will very likely be the less shear stable oil (more polymers in it) and if so it will lose more HTHS and KV than the other. So aside from answering the initial question which implied virgin oils, I'm answering it for used oils which is what matters. My answer is that the oil with higher initial HTHS but same KV at 100C is most likely to allow more oil pressure in the used oil condition. There may be exceptions and scatter in the trend but that's life. I think there is data to show better correlation between HTHS and oil pressure (fully warmed engine) than between KV at 100C and oil pressure, but couldn't find a source while I looked.
