Is mobil 1 EP a good oil to run in a pentastar 3.6
Mississippi
I just picked up 6 quarts of mobil 1 ep from wal-mart they had it on sale. Im going to be running it in a 2012 jeep wrangler with the 3.6 jeep has a hair over 500 miles on it and i was going to dump the factory fill tomorrow and put this in. Does anyone run this oil? Any comments on it?
Originally Posted By: Highline9
I would hold onto that oil for a while and run 2 pyb changes at 3k to flush motor first.
+1 Probably a better recommendation for now.
Complete nonsense! Porsche/Mercedes/Cadillac uses Mobil-1 as the factory fill right off of the assembly line! Its a new motor & does not need no mineral oil flush!
Good oil yes. Do you plan more short runs? If so I would use conventional until your ready to go longer oci's.
vinsonclarkjeep,
Mobil 1 EP is fantasticly good to use for your engine. Since you have a 2012 model I wouldn't do anything to void the warranty bychanging the oil too soon.
Mail Clerk
vinsonclarkjeep,
Mail Clerk
How is he going to void warranty by changing to soon?
Thanks for the replys guys i changed it today and its a good thing i did i found some small pin head like shavings in the oil filter but they were very small. So im very happy i listened to some of you guys and dumped the factory fill early. I will prolly do another change around 3000 miles after that i should be good for once a year changes. Oh and btw this has been the easiest oil change ive ever done really simple to change the filter ( went with a wix ) im actually looking forward to my next change because its so easy to do.
