edyvw
$50 site donor 2026
They do, but VW504.00/507.00 is confined to 0/5W30.
See my follow-up.I think I wasn't being clear. All those have 3.5 as the minimum.
Nobody has a minimum above 3.5, do they? The Mil spec is slightly higher, but that's not anyone's OEM.
It is probably valid for the same spec for instance 5w30 504 vs 502, not for a different thickness.And if you paid attention you would see disclaimer not to do that.
It specifically says to not compare it.It is probably valid for the same spec for instance 5w30 504 vs 502, not for a different thickness.
Some added info and viewpoints. Oiling systems (if designed right of course) are able to adequately operate using a larger range of viscosity - ie, Ford for instance will specify xW-20 to xW-50 for the Coyote depending on intended use. If engines couldn't operate as intended over that kind of viscosity range we would never see OMs with a huge range of recommended viscosities depending on what the expected ambient operating temperature. Of course as pointed out earlier, engines recommending xW-16 and lower have special design features to go that low. Oil bottles call-out a specific ILSAC designation on those oils for a reason because they don't want people putting it in engines not specifying a xW-16 or xW-8 grade.Static pressure decreases with velocity to conserve total pressure as dynamic pressure rises. Oil pressure sensors, not always at stagnation points, typically measure combined static and dynamic pressure. Most oil pumps are positive displacement and sized to minimize pressure delay and maintain flow at low idle with hot, thin oil—the worst-case scenario due to:
- Thinner oils flowing faster through the engine's effective orifice.
- Increased internal leakage in the pump chamber.
- Lower RPM reducing swept volume rate and pump efficiency.
Obviously all PD pumps are a bit different in exact operation depending on design, and then throw in the slew of variable volume, even ECU controlled oil pumps used in engines now and it becomes a bit more complicated. I know that the Melling PD oil pumps for GM LS engines with a spring loaded relief valve (ie, the "old fashioned" PD pump these days) certainly do still increase the volume output quite a bit as RPM increases after they start hitting relief pressure.Consequently, most engines reach oil pump bypass/regulation between 1300–2000 RPM (e.g., Cummins engines by ~1400 RPM). Above this, oil flow and pressure stabilize, as excess flow is diverted by the relief valve to prevent overpressure. Only at very high RPM with thick, cold oil might the bypass become restrictive, allowing pressure to rise.
All of that shouldn't really matter if the oiling system and pump as a system is designed well. Back to the fact that a well designed system will be able to use a wide range of oil viscosity and keep the engine happy under all conditions in terms of delivered oil flow volume. A good oiling system is way more versatile than most people realize. Just the fact that it can keep an engine from being damaged with below zero cold starts using the right W grade shows that with viscosity still magnitudes thicker than any grade at 200F. The other side of the formula for lubrication success is to use the right W grade for anticipated low temp cold starts, and use a KV100/HTHS viscosity that will give some MOFT headroom between moving parts for added wear protection in all anticipated use conditions.Thicker oil doesn't increase pressure in the typical operating range; it lowers the RPM at which regulation occurs. Thinner oil raises it. Since pressure is regulated, thicker oil reduces parasitic flow through the engine's effective orifice, not increases pressure, except below regulation (e.g., <1400 RPM).
Yeah, that pesky physical fact of Tribology ever since two moving surfaces were separated by a film of oil.None of which invalidates the physics behind how an oil lubricates an engine and how wear is controlled. It's still a fact that a higher film thickness results in lower wear.
Probably we should have a better way to use Lubrizol or Oronite charts. I agree that thicker oil has better last layer protection (base oil film strength) than thinner oil. However, without running UOA on each particular engine, we do not know thew wear number, just argument and hypothesis.
Those Melling pumps have inadequately sized bypasses unless they were specifically engineered to allow so much pressure creep.Some added info and viewpoints. Oiling systems (if designed right of course) are able to adequately operate using a larger range of viscosity - ie, Ford for instance will specify xW-20 to xW-50 for the Coyote depending on intended use. If engines couldn't operate as intended over that kind of viscosity range we would never see OMs with a huge range of recommended viscosities depending on what the expected ambient operating temperature. Of course as pointed out earlier, engines recommending xW-16 and lower have special design features to go that low. Oil bottles call-out a specific ILSAC designation on those oils for a reason because they don't want people putting it in engines not specifying a xW-16 or xW-8 grade.
As most know here, OMs these days (except vehicles in other non-CAFE countries) basically "recommend" the lowest viscosity the engine can "safely" use - CAFE driven for max fuel economy. A few OMs that are tied down by CAFE may stipulate one grade higher if the recommended grade isn't obtainable, or say that using a higher viscosity is advantageous for more strenuous driving conditions (Toyota's way of thumbing their nose at CAFE).
Lots of people get hung up on stuff like "thinner oil flow better and therefore cools better" but what they don't realize it that it's a small factor (if it even exists) and doesn't really matter. If that was such an over-driving factor to use thinner oil, then why would Ford and many other makers of high HP cars focused for track use specify thicker oil, not thinner. What matters is getting enough oil volume of adequate viscosity for the operating conditions of the engine. A well designed engine and oiling system can do that over a large range of oil viscosity.
This performance graph shows how much the oil pressure still increases after the pump starts getting into pressure relief on two different pump model with different relief springs installed. You can see when the pump hits pressure relief when the pressure curve goes from exponential to rolling over. The increasing pressure after start of relief means the associated output volume is also increasing. The pump design and relief spring are designed into the system to obtain this kind of output performance - that's all that can be done with a simple spring loaded PRV. PD pump swept area is way over designed so the pump will put out plenty of flow at low RPM, and then the pressure relief system is designed to obtain an adequate volume output over the entire engine RPM range.
All of that shouldn't really matter if the oiling system and pump as a system is designed will. Back to the fact that a well designed system will be able to use a wide range of oil viscosity and keep the engine happy under all conditions in terms of delivered oil flow volume. A good oiling system is way more veritable than most people realize. Just the fact that it can keep an engine from being damage with below zero cold starts using the right W grade (oil still magnitudes thicker than any grade 200F oil) shows that. The other side of the formula for lubrication success is to use the right W grade for anticipated low temp cold starts, and use a KV100/HTHS viscosity that will give some MOFT headroom between moving parts for added wear protection in all anticipated use conditions.
On a side note - some people get hung up on "pump slip". If a PD pump is going into pressure relief at relatively low RPM then pump slip disappears out of the equation. Once the pump is in pressure relief, no level of pump slip matters. If a PD has too much pump slip when not in pressure relief, then it's an ill designed, badly manufactured or very worn out pump.
It has to be by design - Mellng is pretty much the gurus of high performance aftermarket oil pumps. If the PRV started opening much later the oil volume output and associated pressure would be crazy high at pretty low RPM (ie, your drawn in orange line which is zero pressure relief). The hand drawn blue line couldn't be possible without pressure control way down to idle RPM on a pump with even more output volume per rev. There is only so much you can do on a fixed swept volume PD pump with a spring loaded PRV.Those Melling pumps have inadequately sized bypasses unless they were specifically engineered to allow so much pressure creep.
You can see quite clearly that the relief is just switching from one exponential orifice curve to another.
I've drawn the "amputated" parts of the open and closed curves suggested by the yellow curve:
Yes, an undersized PRV could not allow the PRV to control to its best possible ability - the size of the valve and the short path after the valve needs to be optimal. Melling is aware of that, and makes the PRV work as well as possible with a simple spring loaded PRV. The performance of the PRV is built into the overall pump design to provide the volume output performance curves show above. They also strive to reduce oil cavitation at high RPM ... another pump consideration. Melling has been in the oil pump business since 1946, so I'd expect they've figured out how to tweak a PD oil pump by now.The point here is not so much that oil pressure is constant with RPM, but rather that an increase in viscosity produces little to no increase in oil pressure in most cases, which the rise in pressure depending on just how "undersized" the oil pressure relief/bypass is.
Right, but the text states relative performances within the same specification, so like ACEA 2012 vs ACEA 2016 with A3/B4 for example, or the 2008 version of 229.5 vs the 2018 version of 229.5. So it gets a bit dubious once you start trying to compare different specifications, even from the same OEM.
this applies to the original case as well--504 only allows 5w30/0w30.That makes sense now. I thought I only cannot compare between different standard like API vs ACEA. It's not explicit enough. For API, I believe SQ is better than SL, SM, or SN. and ILSAC 6 is better than 4 or 3.
For OEM or ACEA standard are tricky because they do not go through the whole viscosity and SAPS range. 508 is specific to 0w20, not comparable to 504 or 502.
