Mobil 1 ESP 5w30 for 502.00 Spec
Alot of people seem to be very happy with Mobil 1 ESP over the usual Mobil 1 0w40 Euro, Castrol 5w40 Euro, etc. I know its a 504/507 Spec oil that is technically backwards compatible with 502, but my question is, is there any reason to not run it? Engines in question are all EA888 Gen 3 engines spec'd for 502. I suppose my biggest concern would be sheer, Ive always opted for a 40w oil for added sheer protection in case it sheers to a 30w, but after seeing a few people suggest ESP for track use, I'm unsure. Thanks!
In EA888 absolutely use ESP 5W30.
on track? I would go definitely W40 and not any W40.
This specifically isn't a track application, I've just seen it suggested. This car is tuned making around 80 HP above factory and does see some spirited driving, but no track
I'm running the last batch of Valvoline MST 5w-40 in my 2.8l Duramax now. I use it for towing a 4,200lb travel trailer. I was adamant about using a 5w-40 but have a bunch of ESP 5w-30 I'll be using. ESP 5W-30 hths is > 3.5 and it's viscosity although not quite as this as a 40, it's still considered one of the thicker 5w-30's. Any other 5w-30, I'd say no to, but ESP is better stuff in my opinion. Run with confidence.
Motul X-Clean 5W40 GEN2
Mobil1 ESP 0W40 X3.
Gets interesting for the M1 ESP 0W40. From what I can gather, the M1 ESP 0w40 for the Euro market is labeled X3 and is VW 5.11 and has other Euro car approvals. Then there is M1 ESP 0w40 (not labeled X3), and appears to only have Dexos2 approval? This appears to be a North America offering.
Mobil 1 ESP Formula Full Synthetic Motor Oil 0W-40
I think X3 is also making its way here too.
But regardless, I would go Motul.
Ran both former M1 ESP Formula 5W-30 and current M1 ESP 5W-30 too on several 2.0T,
even on track a couple of times without a single issue. No tuning though. Very most VW
504 00 are on the upper end of SAE30 (~12 cSt) anyway and HTHS is between 3,5 and 3,7
mPas.
I agree VW 511 00 is a worthwhile alternative. If you haven't stumbled across my posts on
another thread:
I wish Volkswagen would declare VW 511 00 entirely backwards compatible with VW 502 00, but I guess they won't due to reduced SAPS levels on 511 00 and sulphur in some countries fuels. However I have a hard time to imagine this to be any issue in Europe, where most gasoline VW/Audi engines are specced for both VW 504 00 and 502 00 and fuel is ultra-low sulphur by law.
One of my favorite oils comes with VW 511 00 and I'd bet the new approval exceeds the old one in some ways and at least matches it in others. VW 511 00 seems to merge the strengths of VW 504 00 and 502 00. Strong viscosity incl. HTHS and great wear protection along with reduced SAPS and enhanced 'DI-friendlyness'. Both haven't been that far off anyway, but it limits choice. Oils with VW 511 00 don't come with VW 502 00 simultaneously.
I understand that Volkswagen isn't too deeply interested in older VWs and Audis running anything different than VW 504 00 oils.
Ravenol RUP 5W-40 had VW 502 00 and 505 01 approvals before and now comes with VW 511 00.
I'd happily run REP 5W-30 in the GTI exclusively as well, but as REP doesn't come with VW approvals
and I do every second change at the dealer, who allows me to provide the oil, I need something that
comes with an actual VW approval (VW 502 00 or 504 00). So far I'm going for Ravenol VMP with VW
504 00, as it's most similar to REP, but it lacks the Tungsten-based FM package (probably Vanderbilt
W-324) which both Ravenol REP, RUP (and RCS) come with. I admit it's kind of a first world problem.
This is the latest list of VW 511 00 approved oils and I'm convinced it'll grow:
https://erwin.volkswagen.de/erwin/downloadStaticFile/volkswagen/files/oil/step_51100.pdf (this link automatically directs to the LATEST VW 511 00 list)
Audi Original Teile Special Performance Motorenöl SAE 0W-40 51100
BP Visco 7000 C SAE 5W-40 51100
Castrol EDGE M SAE 5W-40 51100
CHAMPION OEM SPECIFIC C3 SAE 5W-40 51100
EUROL FLUENCE SAE 5W-40 51100
FUCHS TITAN GT1 FLEX 3 SAE 5W-40 51100
GALP FORMULA LS LONGLIFE TECH SAE 5W-40 51100
Liqui Moly Top Tec 4110 SAE 5W-40 51100
Mobil Mobil 1 ESP X3 SAE 0W-40 51100
MOTUL 8100 X-CLEAN GEN2 SAE 5W-40 51100
RAVENOL RUP SAE 5W-40 51100
ROWE HIGHTEC SYNT RS DLS SAE 5W-40 51100
Shell Helix Ultra ECT Multi SAE 5W-40 51100
TOTAL QUARTZ INEO FGO SAE 5W-40 51100
Volkswagen Group HIGH PERFORMANCE GENUINE ENGINE OIL SAE 0W-40 51100
WOLF OFFICIALTECH C3 SAE 5W-40 5110
(5.2021)
12 oils are 5W-40, only three are 0W-40. Or should I say only one is 0W-40? If M1, Genuine VW and Original Audi are the same stuff?
mPas.
another thread:
IMO if oil temperature is below 250f, W30 on track is ok. But above that I would always go thicker due to oil pressure.
Not sure since that has been some time ago, but I'm certain I never reached 250°F. On the Mk7.5 oil temp never exceeded 233°F. Above 240-250°F I'd likely go 5W-40 and preferably VW 511 00 too.
To round things up, let's provide the same for VW 502 00, 505 00, 504 00 and 507 00 as well.
VW 502 00 along with 505 00:
VW 504 00 along with 507 00:
Again, these links automatically direct to the latest list.
Depends where the track is. Generally, 4cyl engines are very easy to cool off.
Come here in Colorado on track I go, and I have never seen VW GTI or R without an upgraded radiator and some kind of oil cooler. Altitude is the most difficult to deal with when it comes to cooling.
