My 1985 Corolla 4A-LC engine occasionally experiences light pinging, especially climbing a gentle hill, when the transmission shifts to overdrive at low throttle and low speed (approximately 41+ MPH, the lowest speed for overdrive). This happens especially when the ignition timing is advanced, which makes the spark plugs run hotter. I like to keep the ignition timing about 4° more advanced than the factory spec. See this YouTube video explaining how advancing timing could increase the spark-plug firing-end temperature and cause preignition.
Interestingly, this only happens at low speeds -- when the transmission shifts to overdrive at low throttle. I also experienced the exactly same phenomenon regularly on a 2009 Corolla 2ZR-FE engine. If this is preignition, which probably is, it's certainly not as violent and damaging as low-speed preignition (LSPI) that happens in turbo gasoline direct-injection (TGDI) engines. Nevertheless, it does only happen at low speeds and there seems to be some similarity in certain aspects, even though the two phenomenons otherwise dramatically differ. Some people strongly disputed that when I suggested it last time.
Now, here is the interesting thing. I've started running the PAO-based Mobil 1 Extended Performance 0W-20 SN PLUS. I'm delighted that my engine runs extremely well with it -- as smooth and efficient as it can be, the engine sounding and feeling like clockwork. I don't think I've had any other oil come close. I've tried to create some pinging events but I have been unsuccessful. Has the SN PLUS actually prevented the occurrence of possibly preignition-related pinging in my engine? It could well be the case. If that's the case, then SN PLUS oils are well worth it in any kind of engine, regardless of whether they are TGDI or not. It will also be interesting how the car will do at the low-speed dyno testing (15 MPH) of California emissions this fall, which is something it always struggles at because I set the ignition at an extra 4° advanced. It will be great if it actually helps reduce the emissions despite the more advanced timing. Interestingly, it does better in the higher-speed (25 MPH) dyno test; so, it could be somewhat preignition related.
Has anyone seen similar benefits using SN PLUS oils, which have reduced calcium and added magnesium?
