It is listed as compatible on their website Granted it isn't technically approved by the manufacturer but it works well. I have used it in several ZF's even in BMW applications.I wasn't aware you could use max life in these Zf 8 speeds
That is the new version of the red bottle right?I have done 20k and will do 40k with the Zeus juice - but at 60k it will be out of warranty and something else goes in …
Maybe the new Valvoline EP - working great in our 6L80e![]()
Does that include power steering pump use also?
I’ve used ML ATF in my Subaru PSF reservoirs for about a decade or so now. I’ve done both turkey baster method and removing the return line and feeding new fluid in while the old is pumped out of the system. Either works well.Does that include power steering pump use also?
Dumb question: is the fluid itself still dyed red?That is the new version of the red bottle right?
YesDumb question: is the fluid itself still dyed red?
Mobil 3309 is what I've always used.I've had Maxlife LV in my Ram 3500 with the Aisin for a few years now, over 60,000km. Works just as good as it did new.
I was going to do a nother drain and fill with it but the prices after covid went stupid. Used to be around 6$ a litre tax in but it's now over 10.
They aren't too fussy in most vehicles.Does that include power steering pump use also?
