MaxLife vs Toyota WS
Originally Posted By: MaximaGuy
Originally Posted By: lexus114
when you do a cooler line flush, is the oil automatically at the right fluid level afterward? since i have no stick its much more of a pita to check afterwards.
I did a return line flush on my ES with RL D6, 8Q out and 8Q in (that is the capacity of the transmission), no level checks etc.
Quite happy with D6 and the WS is quite dirty and worse than the T-IV I drain from my other vehicle (I had 50K on the ES when flushed).
I did loose 2MPG on D6 which I am slowly gaining back - if you ever flush always reset the ECU by draining the battery.
i know what you mean re; that part. so you did no fluid level check then huh? which trans line is the suction line? do you remember?
There are 2 lines to the transmission, the one of the top is the return line.
Yes, disconnect the battery after a flush to have the transmission re-learn
