as examples, powerstroke 6.0/cummins/duramax are all "pushrod" 4valve per cylinder engines. I don't know of any OHC medium duty engine, there is a reason pushrods are favored for industrial engines, also, I don't think honda makes industrial engines.
I did a quick search on Google and everything I read indicates "pushrod" valve actuation is more efficient than OHC due to inherent mechanical losses.
It takes a given amount of torque to maintain a vehicle at a given speed. highway fuel mileage is an especially good estimate of an engine's "efficiency" at producing the needed power to maintain highway velocity.
I don't understand why people insist OHC is more "modern" (actually OHC was developed first) or somehow better. The truth is, for mass market vehicles, where fuel mileage, packaging, weight, servicability, reliability are the main concerns, I can only conclude "pushrod" engines are superior. I simply can't think of any reason to conclude OHC is better. FWIW, I've never owned a vehicle with pushrod valve actuation.
this page gives a bit of info as to the possible future direction of GM pushrod engine technology:
http://www.carcraft.com/techarticles/0303_GM/index3.html
a dual cam in block pushrod design would remove the true advantage of DOHC valve actuation which is independent intake/exhaust cam phasing (variable valve timing).
As to the packaging advantages "pushrod" affords:
Ford’s DOHC 4.6L V8 vs the older 5.0 (4.9) V8
http://www.vorshlag.com/pictures/motor-4.6-4V-004.jpg
And a 1.8L Miata motor next to an LS1
http://www.vorshlag.com/pictures/BothRight.jpg
[ May 13, 2006, 12:07 PM: Message edited by: got boost? ]
