I need a better pickup
Apple Valley, California
Just talking to myself. I need to upgrade from my currant pickup. The cab is too small, no AC, drum brakes etc.
I need atleast a 3/4 ton with a manual trans, must be 4x4, long bed, fuel injected since im tired of messing with Carburetors and AC or atleast had AC.
I don't like the 94 and newer Dodges or 97 and newer Fords. I don't know much about GM's other than the front ends are weak but the engines will run 300k no problem.
I think A diesel is out of my price range. I like 318's, 360's, 351's and 350's. I can fix those.
I'm leaning towards a Ford since they are the easiest to work on. I can replace a heater in one in 20 minutes and other stuff is easy to fix or get to.
Something like this.
http://inlandempire.craigslist.org/cto/2493917375.html
That "looks" like a good truck. I agree, Was that a 351 or 460? Did I miss it?
EITHER WILL suck gas like it's free, but if properly maintained should provide MANY MANY years and miles of great service to you.
The truck in the ad probably has many more miles left in it.
With your requirements, a '92-'97 F-250 or F-350 sounds perfect. All of the engines Ford offered in those were very reliable. IIRC, the 250 used a TTB front axle like the F-150 and Rangers of the time. I think the 350 4x4s have always used solid front axles, but I could be wrong.
You're gonna ditch your sweet little International? That's kinda sad - it's a neat little truck.
But I understand needing something more 'comfortable' to work with regularly.
Ya but I bet a F.I. 351 or 460 will still get better MPG than my currant carbureated 392 with 4.30 gears in the axles.
I think I'm going to find a Ford but would consider an older Dodge but Dodges are hard to find with a bigger cab.
Yes they did! IIRC they also used something stronger than the mazda 5 speed from the 1/2 tons.
fueleconomy.gov says a 1993 f250 2wd comes with the 300-6 and a four speed stick or the 302 V8 and 5 speed. Trucks over 8500 lbs don't have fuel economy stickers, so there may be some unlisted 3/4 ton trucks with HD axles and springs and whatnot.
Whatever that 4 speed is, it must be a rock crusher.
Correct. They DID put 300 I6's in the 250/350 series. The trans ranged from a NP 435 4spd manual with a 6.69 granny gear, T19 4spd with a little taller granny, ZF 42..??? it was a small block version of the diesel zf 5, with similar gearing and a low 1st, the 5spds had OD, the 4spds did not.
My 78 F350 has 3.73 gears, a 300 I6 and the NP 435 trans...
I have loaded 12 round bales on a goose neck that with the truck weighed 32,000lbs and it pulled it. Due to road conditions and terrain I never got over 50mph, but it would have.. I get 11mpg empty and about 9 loaded.
The 300/ Granny box is an EXTREMELY good puller for a gas combo.. It pulled 16k of trailer out of a creek bed but I wound it out in low..fearing if I tried to shift to 2nd I would break something or start rolling backwards..
I had the 300 I6 in an '88 F-250 with a C6 and 4.10's. It would pull the derrière out of the world. Just not very quickly.
I think I need to find one with the 300 inline 6. I remember seeing a Dodge dually with a 225 once. Here in Ca where gas is high priced there are tons of 460's running around. I've only seen a few 300's in my life.
So now I want a 97 or older F250/F350 with a 300, stickshift, 4x4,, extra cab and a busted AC system so I can use that as a barganing chip.
Do you like rust? Do you want to spend $500 in gas to get it home?
There's a 93 by me for $2300.
I used to have a 95 F150 with the 6 cyl and tall gears (3.2 or so.) Everything you read about those motors is true. Would sometimes miss 3rd and shift into 5th. Would pull it.
Hopped on my mountain bike to buzz by this jewel in the rough...
351W, automatic, regular cab. Everything's wrong!
I cant agree with any of you on the 300 Ford V6. I think the 4.6 V8 was a much better engine and has more power, better reliablity and better fuel milelage. It was a V6 that got V8 fuel milelage and still had V6 power. I guess with low enough gears anything would pull. Do yourself a favor and try to find a 4.6 motor, they are bulletproof.
I hate the new body style. Besides being ugly any maintenance is a major undertaking.
9 hrs to replace a heater or AC evaporator. Gotta pull the cab to get the engine out! No thanks!
I can have a heater in the old body style replaced in 30 minutes. An hr to get the evaporator out and the new one back in.
Flying spark plugs etc. No thanks.
False
Completely false
