moribundman
- Joined
- Jun 2, 2003
- Messages
- 23,587
buster,quote:
There are no long life oils with low HT/HS numbers. A3 rated oils are a minimum of 3.5. Mobil 1 are the lowest HT/HS oils that are long life I would say. This post doesn't make sense. What you are calling LL oils here in the US are better at contorlling sludge and deposits. Is the point of the article suggesting the oils in Europe that are LL do not do as well of a job?
There are plenty LL oils with low HTHS. For example, VW 503.00 requires the oil to have HTHS 2.9-3.4, which is lower than non LL spec VW 502.00, which has an HTHS 3.5 min. Nowhere did I say all LL oils are A3-rated.
I didn't call any US oils LL oils. I've previously stated that Mobil 1 0W-40 meets A3 and is approved as a LL that meets VW 503.01 (LL spec, but not with low HTHS!). That's not (yet) applicable in the US, though.
Your last observation is accurate. Indeed, it seems that a number of people in Europe does not believe LL oils are as good as non LL oils. If there is nothing to this claim, can we safely assume that the increase of sludge and premature engine wear, which seems to coincide with the introduction of LL-prepared engines and LL oil, is solely caused by the extended drains (up to 40k KM), but that is has nothing to do with the LL oils per se? I'd rather not assume...
