Originally Posted By: Gurney
Colonel, I am almost, but not quite, at a loss for words.
You are perhaps the proverbial Poster Child (so to speak) for 0W/5W-20 motor oil, and come to discover, you have a closet full of the thickest of 30 weights known to mankind, which
you use in a Toyota Hybrid.
Res ipsa loquitur.
Clearly, there's not that much ambiguity in the Toyota owner's manual after all.
We don't have to wait for your UOA to know what I and many others have been saying for years. Namely, we may not need the margin of protection 5w30 affords us -- as you say, the jury's still out on that issue -- but it certainly is reassuring to know we have it, and we'd be d**m foolish not to put it there. That's why you buy the stuff.
Not only am I and my many clients deserving of a directed verdict, you're lucky we're not moving for costs and fees.
A Toyota Hybrid with a sump full of GC 0W-30. Whodathunkit!
One more time -- it's an ongoing experiment, not a commitment to one grade over another. And one that I'm conducting because I happen to have a
residual stash of GC from the days when I was driving a G35. So no, this is not an "admission" of any sort. Far from it. I'm planning to do future runs with the Pennzoil Platinum 0w20 that I ordered on-line (just try to find that on a store shelf). Keeping in mind the limits of UOA, I'll get both tested and see how they compare after similar OCIs in my 2AZ-FXE.
No ambiguity in the manual? Good grief, now that's where you should have seen a nice
res ipsa. They mention three objectively measurable or definable parameters, oil vis, driving speed, and operating load; and don't bother to offer ANY definition, limitation, or parameters for any of them!!! That would be about as ambiguous as it gets.
Now, at the risk of stoking up the rest of the syrup-worshiping crowd, I'll mention that we actually have TWO hybrids with GC in them. Yep, it's in the Prius too. But that's an entirely different story. The 1NZ-FXE did not get back-speced to 20 wt oils. I suspect, but have no solid proof, that this is a result of the fuel dilution issue which surfaces so often with this engine.
But hey, if an engine never ever shows that it has a need for the use of a 30 or 40 wt oil, then why not use the 20? Many dozens of times, I've asked somebody to explain where all the dead Fords and Hondas are hiding, more than
eight years into the 20 wt "experiment". Thus far, there has been no cataclysmic pandemic of engine failures. I seriously doubt my Camry hybrid needs anything heavier than a 20, and in a couple months, we'll get a glimpse at some data (the two UOA).
Tell you what -- I'll stipulate to a judgment on the pleadings if you can show me a junkyard full of thin-oil-killed cars.
