factorytuned2012
- Joined
- Jul 28, 2024
- Messages
- 1,480
Thank youThis is more of a Home Improvement question - so, I’ve moved it. Interesting discussion, though.
How do these work in a 1" filter frame?I just ordered new filters 3 mins ago. Honeywell MERV 10 14x14x3 and 14x30x3 return filters. Just say no to 1” filters. These have 720 hour (30 days of runtime) on them.
I use 3M Filtrete either 2000 or 2200 ( the premium electrostatic) the only one higher is the 2500 which has some type of app thing. USA made. I exclusively used 3M Filtrete on my last furnace and got 21 years out of it. My new furnace can't handle a dual filter setup ie Coarse pre-filter with the 3M as it is too restrictive. It's a 93% efficient model furnace. Look at the merv or filter efficiency. There are three different types of filter efficiencies listed depending on the manufacturer.what i3m Filtrete wither all your preferences on HVAC/furnace filters?
I was checking out this company out of tx - place called trufilter
they look reputable and solid and also like supporting an American brand especially if they're a small business.
Lowes project source brand is a great price just not sure if they're American made.
Most furnaces aren't designed for a filter thicker than 1" unless specified. My 1" filters last 90-100 days and the backside is spotless.How do these work in a 1" filter frame?
From the picture posted, it appeared to be kind of stepped down with a thicker part above a 1" lower section. My eyes must have deceived me on that.Most furnaces aren't designed for a filter thicker than 1" unless specified. My 1" filters last 90-100 days and the backside is spotless.
There is a step and the additional 2"-3" extends up into the ducting. You have to make sure it is a "return grill" filter. My return grills have a latch that allows them to swing down and then these slide right in and out. It is much better than having to go into the attic to change the filter at the air handler.How do these work in a 1" filter frame?
OH I see. So my eyes weren't deceiving me. NOW, if they made that in a 2" version, I think it would work in my furnace frame. It has room for two filters (two slots) but I don't see any value in using two filter due to possible air flow restrictions.There is a step and the additional 2"-3" extends up into the ducting. You have to make sure it is a "return grill" filter.
I never understood the logic in that statement . Sure , as the pores stop up , less dirt gets through . Also less air . And it's harder on the system trying to pull air through a restricted filter .Buying cheaper filters and changing them every 30 days is a poor idea.
You are letting more dirt and dust get by.
Filters are more efficient as they get dirty.
Correct, you do understand.Sure , as the pores stop up , less dirt gets through .
Same as a higher MERV filter.Also less air .
Incorrect.And it's harder on the system trying to pull air through a restricted filter .
making the fan moter work harder and possibly shortening the motor life.
I used to buy those "better" filters too until our furnace quit working one winter. All that was wrong was a limit switch and the HVAC said the heavy filters can restrict the airflow too much and cause that. He recommended using the inexpensive filters and change them monthly. I trust his knowledge....I hadn't realized just how much I was choking my system by using "better" filters
I said " The system " , I didn't say " the motor " . The system is trying to cool the house . The efficiency of " the system " is reduced because it's not moving air over the coils . It's having to run longer as well . I can see where you could misunderstand what I meant .Correct, you do understand.
Incorrect.
Work by a motor is measured in amps.
The less air it moves, the less work it does and the lower the amps.
A lot of people misunderstand how that works.
If you have an ammeter, you can prove that to yourself.... or you can just trust me.......
or you can probably google it and get varying answers.
seems like more resistance over the filter will create more work for the fan/motor and air flow,,,sorry i worked with hvac in a large hospital for over 30 years,but always looking to learn something new.Incorrect.
Less air means the motor does less work.
Less work means lower amps.
Lower amps will not shorten motor life.
No need to get your feelings hurt.I can see where you could misunderstand what I meant .
A lot of people misunderstand this.seems like more resistance over the filter will create more work for the fan/motor and air flow,,,sorry i worked with hvac in a large hospital for over 30 years,but always looking to learn something new.
