Originally Posted By: Tempest
Quote:
the question then becomes how many psi @ 6500rpm is enough for adequate engine protection?
is 10 psi per 1000 rpm enough?
This is something that I have never figured out.
Wheel bearings and cartridge bearings have zero flow and zero pressure, yet they seem to last a very long time. (Yes they are closed bearings but that is another matter.)
Now, why does oil pressure go up as engine RPM's go up? Higher volume being pushed into the same area. BUT, there must be a restriction preventing that extra oil from going some place. SO, that means there is a back log of extra oil that is not needed by the bearings causing higher pressure.
So how does this 10psi per 1000 rpm come about? It just doesn't make sense to me and we know that the oil pump does not produce the hydrodynamic film. Rotational motion of the bearing does.
Yep, the bearing doesn't need ANY pressure to operate as a hydrodynamically lubricated bearing. I've seen big bearings actually operate under suction on the oil feed in side, where the low pressure side of the bearing sucks on the supply control orifice.
The pressure is the mechanism through which sufficient oil to replenish and cool the bearing is supplied to the bearing.
The 10 psi per 1,000 Revs is an old Small Block race rule of thumb to ensure that there is sufficient oil volume to keep the bearing fed at the most remote drilling of the oil galleries, when the pressure set point is controlled at the oil feed in point.
If pressure were controlled at the worst bearing, then the recommendation would be a fraction of that.
