Me too. Dollar store generic zip-lock sandwich bags are economical.Baggies with labels and lots of cell pictures.
Same here , small carboard box and a magnetic tray(s).Bolts in cardboard is good, baggies with marker is good, but usually I don't take stuff apart and wait weeks before getting back to it. So I usually just have a mess and hope I remember where it all goes.
Will say, sometimes I can thread the bolt back into whatever place it came out of, after removing the bracket or whatever. No labeling required.
Those little magnetic trays, those can be nice, place several on a vehicle, wherever the bolts came out of.
I have these and they are awesome.Haven't used these personally, but they look very handy.
Boltster- Home of The Original Flexible Bolt and Fastener Organizer
The best bolt and fastener organizer available! Great for aviation, woodworking, junk yards, mechanics, and much more. Better than your old magnet tray or push through cardboard bolt diagram by far! Never lose your bolt and fastener orientation again!. Heat resistant, chemical resistant, and...boltster.com
That's a good one- I drilled a drain hole in the casting.Dont miss the bolt under the distributer gear.
+2same
Yes, if it's a going to be a while for whatever reason, I use small clear bags to sort and organize.For the photo memory bunch, doesn't work good if the item is torn apart for months on end waiting for parts, and other items are in the works as well.
When I did a ground-up restoration of a pre-A 1954 Porsche i took photos of each assembly and put bolts And nuts in ziptop baggies with stickies inside indicating what it came off. Worked well, because it took over 4 years to complete, and I have problems remembering what I had for breakfast that day.I recently dropped an oil pan on a 3/4 ton Chevy. I also had to drop the front axle a bit. On the way to the shop where I did the work, I picked up a box of 1/2 cup canning jars. I took the tops off and arranged the jars in a row. As I disassembled things, I place the bolts in groupings in the jars, starting at the left and working right. With the jars being clear I was able to clearly see the bolts. When re-assembly everything I just looked at the jars and brought out the bolts and nuts and worked right to left. It was a great way to keep me organized. I'll certainly do it again. What works for you?
Butter fingers.Metal cans and muffin tins as well
Glass jars not good IMHO.
I mean when they say swinging wrenches......Butter fingers.![]()
