Originally Posted By: Gator
I just changed Oil, went with P Ultra, just completed 1000 miles in 3 days, looking in the oil fill hole it didn't clean not 1 bit. 155,000 on car, the side of the valve cover still has the slight brown tint of varnish to it and so far the Ultra hasnt cleaned any of it.
Why do you feel the inside of an engine MUST be absolutely, squeeky clean? Do you feel that is will make the engine perform better? Get better MPG? What is with this obsession? I've seen dozens of engines that have reached 200,000 miles with mild oil varnish and it has no effect on the performance of the engine at all.
Engines are not hospital operating rooms, or aerospace clean rooms, but hot, dirty, chaotic environments that are not expected to be absolutely-perfectly clean. Oil should keep sludge to a minimum and slight discoloration or varnish of the parts is normal and to be expected in high mileage engines. You are putting way too much effort into something that has no measurable effect on the engine performance or longevity.
If you want to eat off the inside of your engine, change the oil every 100 miles and steam clean the inside of your engine weekly, otherwise change the oil according to reasonable OCIs and enjoy driving it.
There is no Cleanest Inside the Engine Awards in life.
Goodness..........Bob is the Oil Cleanliness Obsession Guy.....BITOCOG
