Reading through this forum is sometimes cumbersome.
You want to learn soemthing new. Example: You read something like "Dont use Diesel oils in Gasoline engines" and the information there reads sound. And along come a Member and tells you: "No, this Information is wrong , because the author was biased."
And now you sit in front of th the screen and think: Who is right?
User A Says: "Theory X about engine oil is correct! " User B says: "Theory Y about engine oil is correct! "
Who´s right?
These engine bearing calculations are spot on with the ones of my car and Motorcycle manufacturers, i have checked and compared the clearances and oil reccomendations given in the OEM shop manuals i have. But there is not a single 0w-40 oil reccomended.
The relationship between bearing clearance and oil viscosity is a delicate balance. Read on for more information on how to get it right!There are some fairly
k1technologies.com
And again, there are no 0w- oils for Motorcycle around. Why? If 0w- oil is the best thing for sporty used, high reving engines? Why?
"But Porsche uses 0w-40!" Yes. But: My car reaches piston speed of up to 25 Meters / Second, wich equals 85 ft/s. How high is the piston speed in these Porsches? Serious Question!
But yeah, Racing team XY and Car manufacturer AB uses 0w-40. who is right? Nobody here pays me for rebuilding my engine if something get´s wrong. And the more you read here, the more confusing and cumberosme it becomes. And, racing teams usually check and rebuild engines, wich i dont do, and they get the oil for free.
I switch to "Only read" mode for the next months. Thank you all for your help and the polite discussion!
