Hplubricants.com is the company website. Advlubrication.com is their retail site; use code BITOG15 to save 15% off your order!Sounds like a great product! Similar price and performance to Redline. i had no prior knowledge of HPL’s reputation, hence why I never mentioned it.
The general opinion? From those who use those products?What is the general opinion on HPL’s products?
Mobil 1 0W40 Euro FS and Redline on my list at the moment. @edyvw is right in that Mobil 1 performs wells and is easy to find and inexpensive, others are indulgences.
Also came across other threads on Shell Rotella T6, thoughts?
Yes.
Surprise, Ravenol has Confessed that they run of tungsten in Production and used other Friction Modfifiers instead for a short time.
In their racing oil wich they advertise heavily as "With tungsten"
Posting. Nr. 84 here in this thread:
https://oil-club.de/index.php?threa...g-5w-40-3-0tfsi-audi-s4-b9-7-000-km/&pageNo=1
Posting Nr. 84 Translated:
"Hello everyone, the employee responsible is unfortunately still on sick leave (I really wish him a speedy recovery), but I was finally able to clarify the situation today: A few days in May 2022, due to supply difficulties, production actually had to resort to additional organic friction modifiers (OFMs - Organic Friction Modifiers) (such as N-tallow-alkyltrimethylenedi) instead of tungsten. The OFMs are more expensive than metal-containing friction modifiers (such as tungsten, molybdenum and sometimes boron), but are very important and effective. This means that this bottling was in no way inferior in terms of friction properties, but was even higher quality and more expensive to produce. It concerns the following bottling at RUP: Bottling date: 05/30/2022 Batch number: W22007131 By the way, the third part of the video from full load deals exactly with the topic of friction modifier additives from minute 6:45. And at minute 7:45 the Alex also talks about the organic FMs. Here is the (very informative) video again: Video: Part 3/5 Motor Oil Additives So in the end it all looks more harmless than I thought. The unfortunate circumstance was that my contact person on the subject had been on sick leave for a long time. And they didn't want to disrupt the lines of communication"
Most members of the forum where not amused about this, thread was locked. You could translate the whole thread with Google translator and read the whole story.
Iirc in BMW track circles it was because it was cheaper than Mobil 1 0w40 and had better viscosity retention.Also why folks use Rotella, a diesel oil, in a gas engine is beyond me when so many good Euro gasser oils exist.
For the LM...no reason to not use the Leichtlauf High Tech 5W40 which has all the approvals vs. the older oils being discussed just to say you have PAO "real" synthetic.
I get your point that Rotella is “technically” a diesel oil, but as Astro pointed out, it is a very good value (but not outstanding like it used to be) that provides great results for the money. Some people likely use it for the fact that diesel oils do not have the ZDDP or other limits on additive %s that API oils do.Also why folks use Rotella, a diesel oil, in a gas engine is beyond me when so many good Euro gasser oils exist.
Undestand - but to recommend an older oil when a current-gen Euro oil exists approvals or not seems mis-guided just to say I'm not running HC/group 3. Yes, could basically run anything now b/c no warranty concern but approvals do provide a standard of performance that is v. high. I'm sure those older LM oils (synthoil energy 0W40 is the one that is PAO-based as I understand it) will work just fine as well. HPL is certainly something that would work well obviously here but has a high cost and not sure what the OPs use case is or intended drain interval.I get your point that Rotella is “technically” a diesel oil, but as Astro pointed out, it is a very good value (but not outstanding like it used to be) that provides great results for the money. Some people likely use it for the fact that diesel oils do not have the ZDDP or other limits on additive %s that API oils do.
Regarding the LM- while I’m not arguing against specs per se, it is kind of hard to push someone to use a spec oil when warranty hasn’t been a concern for nearly a generation (for OP’s vehicle) and there are oils available that FAR surpass any requirement that was even a pipe dream back when the car was originally built.
OP, what’s your intended OCI, and what’s your preferred price target?
Almost.I did, but the de "gschmackle" was not translated to an English adjective or verb. Does it mean that someone put their thumb in the soup?
If you’re referring to the EngineLabs/MotorTrend article written by Lake Speed Jr, well, let’s just say that a couple of the board experts (formulators and blenders) have chimed in that many of the claims made in that article hold no water. This is from actual industry experts, not the vice president of marketing (as LSJ is). So, it’s not as critical of an indictment on diesel oil use in gas engines as the article would have you believe. Just sayin…BTT.... i read here at BITOG a very good article why you should not use Diesel oils in Gasoline engines.
Ya. Too many people place too much emphasis on ZDDP.
Intended OCI is 5-7k milesQ1. What is the use case here? Daily driving? Track?
Basically any of the commonly-available Euro 5W40s (or 0W40s) will do either. HPL Euro 5W40 is another one on the boutique side you can use...no approvals but isn't an issue here (to me) same with Redline I believe.
Daily driving/normal use?Intended OCI is 5-7k miles
Weekend street toy primarily, sometimes DD dutiesQ1. What is the use case here? Daily driving? Track?
I'd just use whatever OTS xW40 Euro oil w/LL-01 approval then and run it for 5K changes.Weekend street toy primarily, sometimes DD duties
