What was the cost of shipping?Ordered - 6qt of Euro 5W40 + 1 qt engine cleaner. I'll give it a whirl.
The Euro adjective?Don't know anything about Walmart, don't shop there, I did not say that they are better, only that if the buyer
want to be sure to get an oil made for euro specs to buy one made in Europe, if M1 is made there for euro diving it ought to be just as good.
What I don't trust is oils made here with the Euro adjective, they may meet euro standards or not, I don't think any of us here is in a position to ascertain that.
I believe $17What was the cost of shipping?
How did I cherry pick? You did that by listing three parameters, I just chose the first one, which you also happened to have capitalized.A good HTHS, with a very low pour point, excellent TEOST and other test results, in combination, absolutely speak to an oil’s quality. Don’t cherry pick one test result and ask your question, look at them all together, in context, and your question is answered.
I don’t know to which “other” brand you’re referring, but I haven’t bought their oil, run their oil in my car, seen the impressive results of other forum members using that product, seen their lab, seen their production facility, or talked with their owner about formulation and testing, so, I cannot speak to their quality.
Maybe that “other“ brand should open their door to you, show you what they’re doing. Show you their detailed results.
If any of those companies would like to come to the board and be as professional and forthcoming with information as HPL has been, I'm sure we would collectively change our tune.Not "cookie cutter" so won't get approved. Those are the exact words Triax used, but they were flogged for it on here.
"Too small to pay for testing." The Mercedes Bevo listings have many tiny oil companies. Triax, Redline, and Schaeffer's were all flogged for people stating that too! Two way street sees traffic 24/7.
Everybody and everything gets flogged on here except @AutoMechanicIf any of those companies would like to come to the board and be as professional and forthcoming with information as HPL has been, I'm sure we would collectively change our tune.
On Triax's own data sheet, their Euro 5W-30 oils do not even meet the minimum required HTHS and they list SA as .8 which is too high for at least one of the specifications they recommend the oil for.
And I do not think Schaeffer's ever gets "flogged" here on the board.
That kid had a rough go of it here at first. Glad he stuck around.Everybody and everything gets flogged on here except @AutoMechanic
Yeah that is true....That kid had a rough go of it here at first. Glad he stuck around.
Maybe Triax should send a rep to take some licks and learn as well?
Nobody and I mean nobody provides data. Is there a database showing how every oil performed at every test sequence for a specific certification? Answer: Nope. Is there any data showing how differences in test results, assuming all meet the min, are reflected in the operational life of an engine? Answer: Nope.As I mentioned many times, lots of claims that it's better. But what does that actually mean? Let's see the data.
This is important statement. It is when you choose to depart from something that just meets the minimum that there are no longer specifications. It then comes down to the knowledge, skill, and integrity of the blender. The test of time will tell set the good ones apart from the types of people that minimum standards are designed to isolate.certs indicate the product meets the minimum requirements which are important to the automaker.
I always read "meets or exceeds" to mean just that - this oil could meet the XYZ approval so in my case VW502 00 but exceeds it. I suppose some get hung on that however and don't trust that it would in fact meet it. The Molygen I have in there now is the same - "also recommended for".This is important statement. It is when you choose to depart from something that just meets the minimum that there are no longer specifications. It then comes down to the knowledge, skill, and integrity of the blender. The test of time will tell set the good ones apart from the types of people that minimum standards are designed to isolate.
My issue is that I, as a consumer, don't know what "exceeds" equates to. It seems most people equate "exceeds" to "better than" or "higher standards" or whatever. I know some boutique oils would have really high levels of additives and it left me wondering if "exceeds" was actually a bad thing as in "too much".I always read "meets or exceeds" to mean just that - this oil could meet the XYZ approval so in my case VW502 00 but exceeds it. I suppose some get hung on that however and don't trust that it would in fact meet it. The Molygen I have in there now is the same - "also recommended for".
This is a valid point. The difference would be the validation that goes on to get there. Maintaining the balance in a formula is the key to good results. This is the same reason aftermarket oil additives in many cases can upset the balance in a formulated oil.My issue is that I, as a consumer, don't know what "exceeds" equates to. It seems most people equate "exceeds" to "better than" or "higher standards" or whatever. I know some boutique oils would have really high levels of additives and it left me wondering if "exceeds" was actually a bad thing as in "too much".
So I have to ask, what data would you want to see?
The lack of data is why things such as certs are important because certs indicate the product meets the minimum requirements which are important to the automaker.
There's no doubt that HPL is probably a very good oil judging by spec's and comments regarding the formulation. It's probably along the same lines as Biosyn from way back.
