Astro14 $100 Site Donor Staff member Joined Oct 10, 2010 Messages 25,735 Location Orlando Nov 30, 2022 #61 Retirednow said: Thanks. Hope you’re working on that Australian distribution.. Click to expand... I had thought you were going to set that up - exclusive importer. No?
Retirednow Joined Dec 27, 2020 Messages 312 Nov 30, 2022 #62 Astro14 said: I had thought you were going to set that up - exclusive importer. No? Click to expand... Too old and sick unfortunately.
High Performance Lubricants Thread starter Joined Nov 27, 2017 Messages 886 Location Manteno, IL USA Nov 30, 2022 #63 Retirednow said: Thanks. Hope you’re working on that Australian distribution.. Click to expand... We have distribution in Australia in the works. I may still be a minute but it will happen.
Ray S Joined Oct 23, 2022 Messages 139 Location San Diego Oct 20, 2023 #64 Graham Piccinini said: Since you use RedLine ATF, I'll throw this in. These are HPL's offerings, if you're ever interested. Just a quick comparo of their current line-up. Click to expand... Is there an HPL approved for ZF 8HP**? There is much talk on Mopar forums by trans shop seeing issue after xxxx miles with non-OEM product.
Astro14 $100 Site Donor Staff member Joined Oct 10, 2010 Messages 25,735 Location Orlando Oct 20, 2023 #65 Ray S said: Is there an HPL approved for ZF 8HP**? There is much talk on Mopar forums by trans shop seeing issue after xxxx miles with non-OEM product. Click to expand... First, this the European motor oil section. You have a transmission question, so that belongs on the transmission section. Second, the HPL team is busy. They can’t read every post. So, when you post your question, in the transmission section, use the @High Performance Lubricants username so they know your post is up. Otherwise, you’re unlikely to get an answer.
Ray S Joined Oct 23, 2022 Messages 139 Location San Diego Oct 20, 2023 #66 Astro14 said: First, this the European motor oil section. You have a transmission question, so that belongs on the transmission section. Click to expand... Was a reply to an earlier post here, https://bobistheoilguy.com/forums/t...e-lubricants-euro-oil-pds.346961/post-6298756 Astro14 said: Second, the HPL team is busy. They can’t read every post. So, when you post your question, in the transmission section, use the @High Performance Lubricants username so they know your post is up. Otherwise, you’re unlikely to get an answer. Click to expand... I would assume they are. I'll re-post to trans... And call next week.
SubieRubyRoo Joined May 15, 2012 Messages 11,636 Location The land of USA-made Subies! Oct 20, 2023 #67 Ray S said: I would assume they are. I'll re-post to trans... And call next week. Click to expand... Mary Jane @ (815) 932-3288
