- Joined
- Dec 20, 2024
- Messages
- 1,706
I'd say - change the oil again before you do that, or at least drain some out and see if it looks, feels and smells like oil.... Is it safe for me to step on the gas and keep the revs up when I try this again?
Change it again and let it slowly reach operating temperature … ?I'd say - change the oil again before you do that, or at least drain some out and see if it looks, feels and smells like oil.
If it was mine, that's what I would do. Rev it and clear it out. Maybe some residual that just needs to be cleared outI'd say it's safe to rev it up and 'blow out the carbon'. But I'm not there and did not see what actually happened. What gives me hope is the smooth initial running. As long as you have sufficient oil, it is likely there will be oil pressure.
Thing is the variables changed pre/post B12, so you really don't know if it was an issue before or now. Start with the basics and keep moving up the chain as each checks out.Good point about the B12. I read quite a few threads about B12 soak on TN and Audi world. Seems like folks changed it immediately and other drove the car spiritedly for 30-40 mins and then did an oil change. I was not comfortable with the latter and decided to just run it in P revving it to 2,000RPMs.
If I had bad compression, wouldn’t the engine have run poorly like it is now even with the prior b12+oil in the crankcase?
I thought about that. But B12 is likely to be be a 'thiner' and dissolve. At this point I'd say rev it up and drive it.Possible clogged oil galley?
That is why I don't like piston soaks, I know it is needed when the masses did not have knowledge, we also did not have the oils or did not know about oils available to possible fix these problem slowly, by just driving. I was going back and forth on doing one, but my problem went away after having Redline Performance ester clean my ring pack and un-jam them. It was by accident and not by design I chose the Redline Performance, just trying another oil and boom massive fuel dilution was gone after 3+ years. Now I run Valvoline Restore and Protect during the winter, and add HPL 40EC to my 5w-40 during the summer to keep my ring packs clean.Thing is the variables changed pre/post B12, so you really don't know if it was an issue before or now. Start with the basics and keep moving up the chain as each checks out.
Context. OP specified in the first post that oil consumption was by moments 1qt per 300 miles. This is pretty much two-stroke territory, at 50:1 ratio if you're doing 25mpg you're doing precisely 1qt per 300 miles.That is why I don't like piston soaks, I know it is needed when the masses did not have knowledge, we also did not have the oils or did not know about oils available to possible fix these problem slowly...
This was my concern as well. But outside of a big chunk having fallen into the sump, I’m not sure if this is possible? This is my first piston soak, so kinda learning along the way. I spent over an hour vacuuming out and blowing compressed air in the cylinders. At least for the stuff at the top, I think I did pretty good compared to the YouTube videos because very little actually came out when I used the starter to spin the engine.Possible clogged oil galley?
Yes sir, she does. Here’s the latest:Does she crank and fire up now?
Correct, I’m not one to jump all in on a piston soak. But 300 miles for a quart had me worried about the cat converters - which are expensive on this thing.Context. OP specified in the first post that oil consumption was by moments 1qt per 300 miles. This is pretty much two-stroke territory, at 50:1 ratio if you're doing 25mpg you're doing precisely 1qt per 300 miles.
At this level, it's all or nothing. You'll clog more expensive stuff downstream if you go for the gentle oil way for thousands of miles. I'm 100% with the OP on that one.
I’ll post back here on the results. If I can get away with 1qt every 2500 miles at this point, I’ll be happy.Sounds like things are moving in the right direction. At one quart every 300 miles you will quickly know if oil consumption is decreased. Looking forward to hearing about long term consumption.
